dexlaine
FTTH FIBER 200MB
Mon Nov 05, 2018 2:37 pm
Has anyone encounter like this also?
I have RB951G-2Hnd works almost 1 yr already upon upgrading of firmware my speed become very slow... but when I put my LAPTOP direct to MODEM I got the 200MB but using RB951-2Hnd becomes 50% speed or lower than that... any problem with the firmware?
Dex
Steveocee
Re: FTTH FIBER 200MB
Mon Nov 05, 2018 4:45 pm
This implies that the router is certainly capable;
https://mikrotik.com/product/RB951G-2Hn ... estresults
Most likely an issue with your configuration. Can you post an export for all to see?
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
R1CH
Forum Veteran
Forum Veteran
Mon Nov 05, 2018 6:20 pm
At that speed you should make sure fasttrack is working, I have 500mbps with fasttrack no problems.
vilpalu
Tue Nov 06, 2018 9:56 am
Main problem is 10/100 Ethernet ports, so its impossible to get more that 100mbps using one port. Upgrade to new device like HEX with 1gbps port.
vecernik87
Long time Member
Long time Member
Tue Nov 06, 2018 10:03 am
Main problem is 10/100 Ethernet ports...
It is RB951G - it has gigabit ports. I believe you got it confused with "non-G" version
Users browsing this forum: No registered users and 23 guests
