MUM Europe 2020
0012nish
RB4011 POE problem
Thu Nov 22, 2018 4:14 pm
I've just got my first RB4011 and it works fine except the port 10 which is POE port, wich give the rate of 10Mbps with POE
any idea..
Nizar
nescafe2002
Long time Member
Long time Member
Re: RB4011 POE problem
Thu Nov 22, 2018 4:21 pm
Didn't notice before, but I have the same issue: RB4011 <=> cAP ac autoneg 100Mbps, non-autoneg 1Gpbs.
sebastia
Thu Nov 22, 2018 8:33 pm
Are you guys(?) using GB compatible POE injectors?
https://mikrotik.com/product/RBGPOE
Quindor
Thu Nov 22, 2018 9:41 pm
I think they are talking POE out, not in.
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
0012nish
Thu Nov 22, 2018 10:04 pm
Yes, I'm using POE out !!
sebastia
Fri Nov 23, 2018 6:28 pm
My bad: no injectors involved. Have you checked with support, as that's hardware related?
pcunite
Fri Nov 23, 2018 6:37 pm
I'm also using an RB4011, ether10 is PoE powering an hAP AC correctly. What hardware are you using on port 10?
0012nish
Fri Nov 23, 2018 9:05 pm
I'm using an Aerohive AP
storp
Sat Nov 24, 2018 12:31 am
Haven't seen the problem, I'm powering a cAP without any problems with PoE out from port10 on a RB4011. But the cAP only have 100Mb port.
Quindor
Re: RB4011 POE problem  [SOLVED]
Sun Nov 25, 2018 4:17 am
Wait, does that device even support powering using Passive POE? I can see it supporting active POE over mode A, not passive/mode B.
Maybe it does but only using 100Mbit but can't find anything about it being officially supported for your device.
There is a difference between mode A and mode B POE, they use different cables and can cause different connection speeds if mixed incorrectly. Worst case they fry equipment! For more information about the differences, I wrote a bit about there here a while back.
0012nish
Mon Nov 26, 2018 10:03 pm
Yes, it looks like you are right :( unfortunately MT poe is Passive while Aerohive is Active.
Thank you
Users browsing this forum: darkprocess, Mett and 32 guests
