lapsio
PWR-Line block diagram - lack of PLC interface?
Fri Dec 14, 2018 11:07 pm
So uh... This diagram on website:
Doesn't include powerline link interface. So how this device implement visibility of powerline link in ROS? Is it like PPP Serial similar to 3G modems? Or regular ethernet? Or something else?
Does it allow for regular interaction like using VLANs etc? How about MTU?
MTCNA, MTCRE, MTCINE
mada3k
Re: PWR-Line block diagram - lack of PLC interface?
Sat Dec 15, 2018 12:15 pm
I don't have the PWR-Line but I have a smilar kit from TP-Link (AV1200 8030 something) and it uses Qualcomm/Atheros chipset. Using VLAN works fine.
My guess is that the PLC-chipset (AR7420) is connected to one of the (5) integrated ports on the QCA9533 with RMII-interconnect. So it's basically Ethernet.
https://www.qualcomm.com/products/qca9531
https://www.qualcomm.com/products/ar7420
Manages some CCR's, RB750Gr3, RB922 and wAP's
normis
Mon Dec 17, 2018 2:09 pm
You are right. We will update the drawing soon.
becs
Tue Dec 18, 2018 10:32 am
It is true, PWR-Line interface appears as another wired interface in the RouterOS.
The PL6411-2nD and PL7411-2nD block diagrams have been updated.
https://i.mt.lv/cdn/rb_files/PL6411-2nD ... 095441.png
https://i.mt.lv/cdn/rb_files/PL7411-2nD ... 095520.png
Users browsing this forum: Takashi and 26 guests
