bkieser
SXT SA5 ac - Board led on but no ethernet and no wifi LEDs
Sat Dec 15, 2018 9:15 pm
I have a brand new, straight out the box SXT SA5 ac. Plug in the PoE power, connect up the ethernet. The LED on the board inside the unit lights up, so the circuity has power, but there is no connection on the ethernet (router LEDs don't flash), no response to ping 192.168.88.1 and connecting directly to PC ethernet and running winbox doesn't detect anything either.
Is there some secret power switch that is undocumented that needs to be turned on? How do I boot this thing?
bkieser
Re: SXT SA5 ac - Board led on but no ethernet and no wifi LEDs
Sat Dec 22, 2018 7:38 pm
Is anyone able to offer any advice on how I could test this? Does it need a special ethernet cable to my router?
ahteran
Sat Dec 22, 2018 7:47 pm
You should try with another poe
bkieser
Fri Dec 28, 2018 6:07 pm
Thank you for the suggestion. I have done this and it makes no difference.
Users browsing this forum: No registered users and 6 guests
