scracha
mUPS suggestions
Thu Dec 20, 2018 12:34 am
Seasons greeting Mikrotik. If you're going to do a mUPS hardware refresh at some point in the future, can you consider a low voltage disconnect feature? At the moment we add an in-line one with the battery(s) but it would be a much nicer product if one were included. As it can already detect when the battery is low and when it's charging it shouldn't be too difficult/expensive to implement.
Also, would you condenser a mUPS version that took an array of lithium 18650D batteries? Would make a real nice one box solution that could be pole mounted.
mistry7
Re: mUPS suggestions
Thu Dec 20, 2018 12:56 am
+1 and ability for up to 2,5A so it is enough to power hex Poe or Powerbox or Omnitik with all ports used...
Users browsing this forum: No registered users and 5 guests
