MUM Europe 2020
leeratanak
POE-IN supported by Cisco POE switch
Fri Dec 21, 2018 11:52 am
Just a quick question. Will Routerboard that support 802.3af/at standard powered by cisco poe switch that support such standard?
Quindor
Re: POE-IN supported by Cisco POE switch
Fri Dec 21, 2018 1:31 pm
I'm not quite sure what you are asking but if it states that a routerboard supports 802.3af/at then it will support that and work with any (most) POE switches that also adhere to that standard. As an example, I use a lot of wAP AC's and those work fine with multiple brands of switches I've tried them on.
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
leeratanak
Fri Dec 21, 2018 8:04 pm
Thanks you very much for your info. I just dont see tested cisco poe switch in mikrotik poe-in chart. Will cisco poe switch work well with routerboard that support 802.3af/at?
Users browsing this forum: Google [Bot] and 18 guests
