MUM Europe 2020
mmx
Faster CPU. Is it in plan?
Mon Mar 05, 2007 11:38 am
Hi
Do you have such plans to make a routerboard with a faster CPU?
If yes, when aprox it will be in production?
normis
Mon Mar 05, 2007 11:49 am
yes, in a few months such product will be available.
yusempron
Mon Mar 05, 2007 1:41 pm
How faster CPU ?
normis
Mon Mar 05, 2007 1:49 pm
2-3x faster
yusempron
Mon Mar 05, 2007 3:30 pm
2-3x faster
faster than RB532?
normis
Mon Mar 05, 2007 3:41 pm
yes!
firebat
Tue Mar 06, 2007 8:03 am
Will they support the 564 daughterboard? I need to buy a 532/564 now but need the faster CPU in a couple of months.
normis
Tue Mar 06, 2007 8:32 am
some of the new boards will support the daughterboards
mmx
Tue Mar 06, 2007 9:22 am
Great
jober
Long time Member
Long time Member
Tue Mar 06, 2007 5:02 pm
2 - 3x faster?
Humm
So is that answer something like this?
rb532 over clocked to 400mhz x 2 = 800mhz
rb532 stock speed 266mhz x 3 = 798mhz
GotNet
Tue Mar 06, 2007 5:20 pm
2 - 3x faster?
Humm
Wow! Now the new POE standard will be PWCOE (Power Water Cooling Over Ethernet). :)
miahac
Long time Member
Long time Member
Thu Mar 08, 2007 5:03 pm
2 - 3x faster?
Humm
Probably a smaller silicon process, 1/4 off the wavelength generally yields 1/2 the size and 2x the speed with the same power consumption(heat).
normis
Thu Mar 08, 2007 5:21 pm
as apple would say ... think different ;)
advantz
Fri Apr 06, 2007 1:34 am
I'm hoping you guys could produce xscale systems :D
thank you
nickb
Mon Apr 09, 2007 6:18 pm
400Mhz is plenty of MIPS cpu, and 32MB is plenty of RAM. What I want to see is a beefier power supply with more mini PCI slots!
Rather than having a ton of CPU power (more is nice, but IMO 400Mhz is plenty), what we need is more power supply capacity and more mini-PCI slots.
Ideally I'd like to see a board with a ~400Mhz cpu, 32 or 64MB ram, and capable of supporting 3-4 XR2 cards :)
csickles
Mon Apr 09, 2007 9:36 pm
I smell an Intel system on chip solution..
Check the recent press from intel about a P4 based system on chip...
I have NO inside info. Just thinking along the "Apple" line, and putting 2 and 2 together...
Craig
Things that make you go "Hmmmmmmmm"...
Craig
miahac
Long time Member
Long time Member
Tue Apr 17, 2007 4:21 pm
well months have passed since the initial announcement of faster chips and I have a multisite ptp project that has been brewing since then. I was hoping to use the faster mt boards but it seems I will be stuck with 532s, it is time to put in my purchase order.
normis
Wed Apr 18, 2007 7:47 am
if you read the forum carefully, you will see that we are presenting new fast routerboards in USA MUM in a few weeks.
jober
Long time Member
Long time Member
Thu Apr 19, 2007 3:29 am
Those damn Americans get to see all the good stuff first. LOL
rockr
Thu Apr 19, 2007 4:17 pm
MUM Nigeria is in a few weeks. Unless you have overclocked the calendar. USA MUM is a month and a half away.
I am looking for more throughput. I am hoping that 2x cpu will give us that. Or are the bottlenecks in software?
miahac
Long time Member
Long time Member
Thu Apr 19, 2007 10:02 pm
well maybe I will go back to the site and replace the busiest node(s) if I am having performance issues.
normis
Fri Apr 20, 2007 7:53 am
MUM Nigeria is in one week, MUM USA is in 5 weeks. There are no bottlenecks in software, on some PC systems we have seen 3Gbits of throughput still with no limit in sight.
yusempron
Sat Apr 21, 2007 5:10 am
Hi normis, would you tell us what are some PC?
samsoft08
Long time Member
Long time Member
Sun Apr 22, 2007 9:36 pm
Hi normis .. faster routerboards ? do you mean RB333 ? comparing it to 532 whts the differences ? and what does those numbers mean ( 532,333) ???????
janisk
Mon Apr 23, 2007 1:08 pm
so, lets start with 532
so, it is 500 series with 3 ethernet ports and 2 miniPCI slots for wireless cards.
so, 333 now :)
300 series board with 3 ethernet and 3 miniPCI
and how much faster if faster, you will find out in MUM in USA, and in Nigeria you will see a roadmap, and see where does it lead ;)
pacman
Tue Apr 24, 2007 9:13 am
Hmmm...
How about the physical size? Will it fit into the same size cases (indoor and out) as the 532?
Loop Scorpio Ltd
providers of rural broadband
firebat
Tue Apr 24, 2007 10:25 am
How can a 300 series be faster than a 500 series? :shock:
normis
Tue Apr 24, 2007 2:53 pm
as it has more interfaces and a different design, it will not fit into the old cases. the series number (300) does not indicate the speed
samsoft08
Long time Member
Long time Member
Thu Apr 26, 2007 1:16 am
so What does 300 and 500 indicate to ?????? size of engine or what ??
Users browsing this forum: clueluzz and 27 guests
