jaskies
RB750 Aluminum Electrolytic Capacitor SMD need replacement
Fri Dec 28, 2018 3:48 am
Hello to all
There is a model rb750 defective RB750 Aluminum Electrolytic Capacitor SMD need replacement located C50 labeled r4 330j cw the search in the network does not find the model and characteristics.
Please help to find out the capacity, voltage, manufacturer, model to replace?
msatter
Re: RB750 Aluminum Electrolytic Capacitor SMD need replacement
Fri Dec 28, 2018 12:57 pm
Write an e-mail to support@mikrotik.com and hope they can give you specific info.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.19 / MikroTik APP 1.3.2
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
karlisi
Fri Dec 28, 2018 3:47 pm
If there is j not capital J after 330, then it is 330uF 6.3V 105*C
Karlis
jaskies
Mon Dec 31, 2018 11:34 am
Tech support answer is:
C50 is a Capacitor PolymerAl 330uF ±20% 6.3V 3.16A 17mOhm 2000h 6.3x5.7 SMD. P/N: MP6VL330MC5R7
Users browsing this forum: No registered users and 8 guests
