starbug
10GB SFP+ recognized as 1GB - Question
Fri Dec 28, 2018 5:54 pm
I do have a RB3011UiAS and a CRS326-24G-2S+ connected via a 10GB SFP+ DAC. Even though both ends are forced to 10GB full duplex they are only shown as 1GB connection within Winbox. The CLI though shows "speed=10Gbps".
Anybody experienced that? What is the truth?
Regards,
Starbug
sebastia
Re: 10GB SFP+ recognized as 1GB - Question  [SOLVED]
Sat Dec 29, 2018 12:33 am
Hey, 3011 is only SFP capable: see https://i.mt.lv/cdn/rb_files/RB3011UiAS ... 123613.png
So max is 1gb
starbug
Sat Dec 29, 2018 2:05 am
So max is 1gb
Thanks, actually I'm embarrassed since I had a look at the block diagram several times and thought even though the channel only provides only 1GB to the CPU it should have a 10GB connection. But I didn't notice it's an SFP only and not SFP+. Aarrrrg.
mducharme
Trainer
Trainer
Sat Dec 29, 2018 4:29 am
The 4011 has an SFP+ port. If you upgrade to that you should get the full rate.
Users browsing this forum: No registered users and 12 guests
