gotsprings
Forum Veteran
Forum Veteran
CRS328-24P-4S+RM POE Problems
Fri Dec 28, 2018 7:41 pm
Trying out my first 328.
The POE seems kind of odd.
I had a Wireless Wire Not Power Up on one port but it did on another.
Then a UBNT CloudKey... plug it in and I get a "poe-out status: current_too_low" complaint. The unit won't power up until I set the port to POE Forced On and Voltage High. The error still shows but it is powering up the CloudKey.
Anyone else seeing similar issues?
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
elbob2002
Re: CRS328-24P-4S+RM POE Problems
Fri Dec 28, 2018 9:13 pm
are you using SwOS or RouterOS? Which verison?
I did have an issue with one port not powering a device and just plugged it into another port and it worked. I thought maybe I hadn't pushed in the connector properly.
I'm running RouterOS 6.43.7 on mine.
Routerboard firmware is 6.43.4 because I can't reboot the switch.
gotsprings
Forum Veteran
Forum Veteran
Sat Dec 29, 2018 4:20 pm
Router OS 6.43.8. Matching firmware.
Mark Twain
eworm
Thu Jan 03, 2019 1:03 am
Try a power cycle on the port:
/ interface ethernet poe etherX power-cycle
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
gotsprings
Forum Veteran
Forum Veteran
Thu Jan 03, 2019 5:56 pm
Unit still won't power up until I force POE to on. But the complaint in red is gone.
Mark Twain
hturkan
Tue Jan 22, 2019 8:20 pm
Hello I had the same problem. I've tried a lot of changes about POE and I haven't succeeded.
What are the predictable reasons for this problem?
Please contact us with our experienced MikroTik team.
Users browsing this forum: No registered users and 20 guests
