bkieser
SXT SA5 ac - Cannot reset. Holding down button or shorting jumper doesn't work
Sun Dec 30, 2018 10:40 pm
Any ideas on this?
I have a SXT SA5 ac. The power light LED is on. Power comes through USB too.
However nothing is working. Doesn't make the chirp sound when powering up. Holding down the black button then powering up doesn't reset it. Shorting the jumper doesn't work.
I have tried 2 different POEs and both with work other units, but not this one.
It's a brand new out-the-box unit. Never been deployed. Not had any damage done to it.Visually looks perfect.
mikrotikrouteros
Re: SXT SA5 ac - Cannot reset. Holding down button or shorting jumper doesn't work
Mon Dec 31, 2018 1:31 am
try using another power supply, 24v 1A
if you connect a computer with winbox can you see the SXT listed ?
bkieser
Sat Jan 05, 2019 2:35 am
I have used a different power supply and I have also used a different POE. No luck.
The LED is on, so this is very strange.
Winbox just can't see it. It can see my other SXT devices, just not this.
Like I said, it's straight out the box, brand new hardware.
Users browsing this forum: No registered users and 3 guests
