Alllex
HOW TO GET SIM CARD NUMBER
Wed Jan 02, 2019 5:41 pm
Hello. How to get the SIM card number on the device wAP LTE, without using USSD command.
mada3k
Re: HOW TO GET SIM CARD NUMBER
Fri Jan 04, 2019 12:00 pm
/interface lte info 0 once
the look for the uicc
Manages some CCR's, RB750Gr3, RB922 and wAP's
eworm
Fri Jan 04, 2019 12:15 pm
:put ([ / interface lte info [ :pick [ find ] 0 ] once as-value ]->"uicc")
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Alllex
Sat Jan 05, 2019 2:56 pm
device info: RouterBOARD wAP R-2nD, 6.42.9 (long-term)
[/interface lte info 0 once] command result:
pin-status: no password required
functionality: full
manufacturer: "MikroTik"
model: "R11e-LTE"
revision: "MikroTik_CP_2.160.000_v008"
current-operator: 25020
lac: 29481
current-cellid: 92210699
phy-cellid: 244
access-technology: Evolved 3G (LTE)
session-uptime: 2d22m41s
imei: [hide]
imsi: [hide]
earfcn: 1450 (band 3, bandwidth 15Mhz)
rsrp: -77dBm
rsrq: -10dB
sinr: 5dB
cqi: 13
Need to get a phone number
mkx
Sat Jan 05, 2019 5:47 pm
Mobile device does not have to know own MSISDN (phone number) for proper operations. For data-only MSISDN is not even needed by MNO's core network.
Written that, mobile device can learn own number through some service exchange, i.e. by receiving an SMS message (which is not data service BTW). You can't send SMS message to the device without knowing it's MSISDN obviously, but you can send SMS message from your wAPr to your mobile ... and send a reply back to wAPr. Check with wAPr if it knows own number afterwards.
BR,
Metod
doneware
Trainer
Trainer
Mon Jan 07, 2019 7:08 pm
as per experience, uicc is only available in 6.43+
if you're looking for MSISDN (i.e. the number you dial), as far as i know you can't.
you can query the IMSI, which consists of these information
- Mobile Country Code (MCC)
- Mobile Network Code (MNC)
- Mobile Subscriber Identity Number (MSIN)
the first two can be looked up here: https://cellidfinder.com/mcc-mnc
for example i have one here:
216301034957618
216 stands for hungary, 30 stands for T-Mobile hungary, and the rest (1034957618) is the MSIN (but NOT the MSISDN)
as you see, this has nothing to do with the +xx phone number notation, but this is the closest you can get to it.
MSISDN is something that is linked to IMSI (the number that is stored in the sim-card) in the MNO's HLR.
but there's a knob in "/int lte info 0", which at least hints something:
subscriber-number: +CME ERROR: 100
sadly i keep getting the same error here (tested on 6.43.4). but you still can send an sms from it to your phone, and you can see the number where the message is coming form.
#TR0359
doneware
Trainer
Trainer
Mon Jan 07, 2019 7:10 pm
btw, this translates to:
CME ERROR: 100 Unknown error
source: CME ERROR (GSM Equipment Related errors) - https://www.micromedia-int.com/en/gsm-2 ... ted-errors
#TR0359
Users browsing this forum: No registered users and 4 guests
