ubikrotik
rbm33g and m.2 slot problem
Sat Jan 12, 2019 2:51 am
I received my rbm33g today. I tried to install a KingDian m.2 32gb NGFF ssd to the m.2 pcie slot but it doesnt work. I cant see the drive appear in /system/disk/. if i try a sd card it works like a charm. But the ssd never appear. What do i do wrong?
mkx
Re: rbm33g and m.2 slot problem
Sat Jan 12, 2019 12:22 pm
Quite probably ROS doesn't include appropriate driver for M.2 SSDs. But you should check with support@mikrotik.com to be sure.
Before anyone asks why HW ports are there if the devices are not supported: they will most probably work after an unicorn pulls ROS7 out of a rainbow ...
BR,
Metod
buzzdee
Wed Jan 16, 2019 11:05 pm
Hi ubikrotik,
I had a similar issue a few months ago:
viewtopic.php?f=3&t=134737&p=663723&hil ... ee#p663723
Doneware pointed out, that the M33G only supports m.2 ssds with pcie interface - all ngff devices listed on Kingdian's website have sata interfaces.
Cheers.
Users browsing this forum: No registered users and 13 guests
