nemke
RBM33G with RB11e-LTE no connection
Sat Jan 19, 2019 9:31 pm
Hello to all
plese HELP
I try to solve problem on RBM33G board but no luck. I have one LTE cart, places on first (pci0) slot, I try with USB jumber on and off, also try to put LTE modem on second PCIe slot (pci1) but the same problem.
I have RBM33G (6.43.8) and MT R11e-LTE (CP_2.160.000_v010)
ROS see LTE lite interface but can't be in running mode. I try RB11e-LTE in other device (LtAP) and work with no problem, with same SIM card. So ther is no problem with LTE model or SIM.
My setup on RBM33G
routerboard: yes
board-name: RBM33G
model: RouterBOARD M33G
serial-number: A2FD0903AD40
firmware-type: mt7621L
factory-firmware: 3.41
current-firmware: 6.43.8
upgrade-firmware: 6.43.8
[xxxxxxx@MikroTik] > system resource usb print
# DEVICE VENDOR NAME SPEED
0 1-0 Linux 3.3.5 xhci-hcd xHCI Host Controller 480
1 2-0 Linux 3.3.5 xhci-hcd xHCI Host Controller 5000
2 1-1 MikroTik R11e-LTE 480
[xxxxxx@MikroTik] > system routerboard usb set type=mini-PCIe
[nemke@MikroTik] > interface print
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU
0 R ether1 ether 1500 1596 2026
1 ether2 ether 1500 1596 2026
2 ether3 ether 1500 1596 2026
3 lte1 lte 1480
[xxxxx@MikroTik] > interface lte print
0 name="lte1" mtu=1480 mac-address=AC:FF:FF:00:00:00 apn-profiles=apn1
network-mode=gsm,3g,lte
[xxxxxx@MikroTik] /interface lte> info
number: 0
pin-status: no password required
functionality: full
registration-status: not searching
manufacturer: "MikroTik"
model: "R11e-LTE"
revision: "MikroTik_CP_2.160.000_v010"
imei: 355654090193447
imsi: 220033300907891
uicc: 89381030000260083094
subscriber-number: +CME ERROR: 100
Those are logs from LTE:
00:44:22 lte,async,raw lte1: sent AT+CSQ
00:44:22 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:25 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:25 lte,async,raw lte1: rcvd OK
00:44:25 lte,async,raw lte1: sent AT+CSQ
00:44:25 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:28 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:28 lte,async,raw lte1: rcvd OK
00:44:28 lte,async,raw lte1: sent AT+CSQ
00:44:28 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:31 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:31 lte,async,raw lte1: rcvd OK
00:44:31 lte,async,raw lte1: sent AT+CSQ
00:44:31 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:34 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:34 lte,async,raw lte1: rcvd OK
00:44:34 lte,async,raw lte1: sent AT+CSQ
00:44:34 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:37 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:37 lte,async,raw lte1: rcvd OK
00:44:37 lte,async,raw lte1: sent AT+CSQ
00:44:37 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:40 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:40 lte,async,raw lte1: rcvd OK
00:44:40 lte,async,raw lte1: sent AT+CSQ
00:44:41 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:44 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:44 lte,async,raw lte1: rcvd OK
00:44:44 lte,async,raw lte1: sent AT+CSQ
00:44:44 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:47 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:47 lte,async,raw lte1: rcvd OK
00:44:47 lte,async,raw lte1: sent AT+CSQ
00:44:47 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:50 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:50 lte,async,raw lte1: rcvd OK
00:44:50 lte,async,raw lte1: sent AT+CSQ
00:44:50 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:53 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:53 lte,async,raw lte1: rcvd OK
00:44:53 lte,async,raw lte1: sent AT+CSQ
00:44:53 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:56 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:56 lte,async,raw lte1: rcvd OK
00:44:56 lte,async,raw lte1: sent AT+CSQ
00:44:56 lte,async,raw lte1: rcvd +CSQ: 0,99
00:44:59 lte,async,raw lte1: sent AT+EEMGINFO?
00:44:59 lte,async,raw lte1: rcvd OK
00:44:59 lte,async,raw lte1: sent AT+CSQ
00:44:59 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:02 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:02 lte,async,raw lte1: rcvd OK
00:45:02 lte,async,raw lte1: sent AT+CSQ
00:45:02 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:05 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:05 lte,async,raw lte1: rcvd OK
00:45:05 lte,async,raw lte1: sent AT+CSQ
00:45:05 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:08 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:08 lte,async,raw lte1: rcvd OK
00:45:08 lte,async,raw lte1: sent AT+CSQ
00:45:08 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:11 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:11 lte,async,raw lte1: rcvd OK
00:45:11 lte,async,raw lte1: sent AT+CSQ
00:45:11 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:14 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:14 lte,async,raw lte1: rcvd OK
00:45:14 lte,async,raw lte1: sent AT+CSQ
00:45:14 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:17 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:17 lte,async,raw lte1: rcvd OK
00:45:17 lte,async,raw lte1: sent AT+CSQ
00:45:17 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:20 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:20 lte,async,raw lte1: rcvd OK
00:45:20 lte,async,raw lte1: sent AT+CSQ
00:45:20 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:23 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:23 lte,async,raw lte1: rcvd OK
00:45:23 lte,async,raw lte1: sent AT+CSQ
00:45:23 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:26 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:26 lte,async,raw lte1: rcvd OK
00:45:26 lte,async,raw lte1: sent AT+CSQ
00:45:26 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:29 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:29 lte,async,raw lte1: rcvd OK
00:45:29 lte,async,raw lte1: sent AT+CSQ
00:45:29 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:32 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:32 lte,async,raw lte1: rcvd OK
00:45:32 lte,async,raw lte1: sent AT+CSQ
00:45:32 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:35 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:35 lte,async,raw lte1: rcvd OK
00:45:35 lte,async,raw lte1: sent AT+CSQ
00:45:35 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:38 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:38 lte,async,raw lte1: rcvd OK
00:45:38 lte,async,raw lte1: sent AT+CSQ
00:45:38 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:41 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:41 lte,async,raw lte1: rcvd OK
00:45:41 lte,async,raw lte1: sent AT+CSQ
00:45:41 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:44 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:44 lte,async,raw lte1: rcvd OK
00:45:44 lte,async,raw lte1: sent AT+CSQ
00:45:44 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:47 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:47 lte,async,raw lte1: rcvd OK
00:45:47 lte,async,raw lte1: sent AT+CSQ
00:45:47 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:50 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:50 lte,async,raw lte1: rcvd OK
00:45:50 lte,async,raw lte1: sent AT+CSQ
00:45:50 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:53 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:53 lte,async,raw lte1: rcvd OK
00:45:53 lte,async,raw lte1: sent AT+CSQ
00:45:54 lte,async,raw lte1: rcvd +CSQ: 0,99
00:45:57 lte,async,raw lte1: sent AT+EEMGINFO?
00:45:57 lte,async,raw lte1: rcvd OK
00:45:57 lte,async,raw lte1: sent AT+CSQ
00:45:57 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:00 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:00 lte,async,raw lte1: rcvd OK
00:46:00 lte,async,raw lte1: sent AT+CSQ
00:46:00 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:03 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:03 lte,async,raw lte1: rcvd OK
00:46:03 lte,async,raw lte1: sent AT+CSQ
00:46:03 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:06 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:06 lte,async,raw lte1: rcvd OK
00:46:06 lte,async,raw lte1: sent AT+CSQ
00:46:06 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:09 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:09 lte,async,raw lte1: rcvd OK
00:46:09 lte,async,raw lte1: sent AT+CSQ
00:46:09 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:12 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:12 lte,async,raw lte1: rcvd OK
00:46:12 lte,async,raw lte1: sent AT+CSQ
00:46:12 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:15 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:15 lte,async,raw lte1: rcvd OK
00:46:15 lte,async,raw lte1: sent AT+CSQ
00:46:15 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:18 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:18 lte,async,raw lte1: rcvd OK
00:46:18 lte,async,raw lte1: sent AT+CSQ
00:46:18 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:21 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:21 lte,async,raw lte1: rcvd OK
00:46:21 lte,async,raw lte1: sent AT+CSQ
00:46:21 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:24 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:24 lte,async,raw lte1: rcvd OK
00:46:24 lte,async,raw lte1: sent AT+CSQ
00:46:24 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:24 system,info,account user nemke logged out from 192.168.88.90 via telnet
00:46:27 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:27 lte,async,raw lte1: rcvd OK
00:46:27 lte,async,raw lte1: sent AT+CSQ
00:46:27 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:30 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:30 lte,async,raw lte1: rcvd OK
00:46:30 lte,async,raw lte1: sent AT+CSQ
00:46:30 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:33 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:33 lte,async,raw lte1: rcvd OK
00:46:33 lte,async,raw lte1: sent AT+CSQ
00:46:33 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:36 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:36 lte,async,raw lte1: rcvd OK
00:46:36 lte,async,raw lte1: sent AT+CSQ
00:46:36 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:39 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:39 lte,async,raw lte1: rcvd OK
00:46:39 lte,async,raw lte1: sent AT+CSQ
00:46:39 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:42 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:42 lte,async,raw lte1: rcvd OK
00:46:42 lte,async,raw lte1: sent AT+CSQ
00:46:42 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:45 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:45 lte,async,raw lte1: rcvd OK
00:46:45 lte,async,raw lte1: sent AT+CSQ
00:46:45 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:48 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:48 lte,async,raw lte1: rcvd OK
00:46:48 lte,async,raw lte1: sent AT+CSQ
00:46:48 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:51 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:51 lte,async,raw lte1: rcvd OK
00:46:51 lte,async,raw lte1: sent AT+CSQ
00:46:51 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:54 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:54 lte,async,raw lte1: rcvd OK
00:46:54 lte,async,raw lte1: sent AT+CSQ
00:46:54 lte,async,raw lte1: rcvd +CSQ: 0,99
00:46:57 lte,async,raw lte1: sent AT+EEMGINFO?
00:46:57 lte,async,raw lte1: rcvd OK
00:46:57 lte,async,raw lte1: sent AT+CSQ
00:46:57 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:00 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:00 lte,async,raw lte1: rcvd OK
00:47:00 lte,async,raw lte1: sent AT+CSQ
00:47:00 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:03 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:03 lte,async,raw lte1: rcvd OK
00:47:03 lte,async,raw lte1: sent AT+CSQ
00:47:03 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:06 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:06 lte,async,raw lte1: rcvd OK
00:47:06 lte,async,raw lte1: sent AT+CSQ
00:47:06 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:09 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:09 lte,async,raw lte1: rcvd OK
00:47:09 lte,async,raw lte1: sent AT+CSQ
00:47:10 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:13 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:13 lte,async,raw lte1: rcvd OK
00:47:13 lte,async,raw lte1: sent AT+CSQ
00:47:13 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:16 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:16 lte,async,raw lte1: rcvd OK
00:47:16 lte,async,raw lte1: sent AT+CSQ
00:47:16 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:19 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:19 lte,async,raw lte1: rcvd OK
00:47:19 lte,async,raw lte1: sent AT+CSQ
00:47:19 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:22 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:22 lte,async,raw lte1: rcvd OK
00:47:22 lte,async,raw lte1: sent AT+CSQ
00:47:22 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:25 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:25 lte,async,raw lte1: rcvd OK
00:47:25 lte,async,raw lte1: sent AT+CSQ
00:47:25 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:28 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:28 lte,async,raw lte1: rcvd OK
00:47:28 lte,async,raw lte1: sent AT+CSQ
00:47:28 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:31 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:31 lte,async,raw lte1: rcvd OK
00:47:31 lte,async,raw lte1: sent AT+CSQ
00:47:31 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:34 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:34 lte,async,raw lte1: rcvd OK
00:47:34 lte,async,raw lte1: sent AT+CSQ
00:47:34 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:37 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:37 lte,async,raw lte1: rcvd OK
00:47:37 lte,async,raw lte1: sent AT+CSQ
00:47:37 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:40 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:40 lte,async,raw lte1: rcvd OK
00:47:40 lte,async,raw lte1: sent AT+CSQ
00:47:40 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:43 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:43 lte,async,raw lte1: rcvd OK
00:47:43 lte,async,raw lte1: sent AT+CSQ
00:47:43 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:46 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:46 lte,async,raw lte1: rcvd OK
00:47:46 lte,async,raw lte1: sent AT+CSQ
00:47:46 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:49 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:49 lte,async,raw lte1: rcvd OK
00:47:49 lte,async,raw lte1: sent AT+CSQ
00:47:49 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:52 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:52 lte,async,raw lte1: rcvd OK
00:47:52 lte,async,raw lte1: sent AT+CSQ
00:47:52 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:55 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:55 lte,async,raw lte1: rcvd OK
00:47:55 lte,async,raw lte1: sent AT+CSQ
00:47:55 lte,async,raw lte1: rcvd +CSQ: 0,99
00:47:58 lte,async,raw lte1: sent AT+EEMGINFO?
00:47:58 lte,async,raw lte1: rcvd OK
00:47:58 lte,async,raw lte1: sent AT+CSQ
00:47:58 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:01 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:01 lte,async,raw lte1: rcvd OK
00:48:01 lte,async,raw lte1: sent AT+CSQ
00:48:01 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:04 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:04 lte,async,raw lte1: rcvd OK
00:48:04 lte,async,raw lte1: sent AT+CSQ
00:48:04 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:07 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:07 lte,async,raw lte1: rcvd OK
00:48:07 lte,async,raw lte1: sent AT+CSQ
00:48:07 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:10 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:10 lte,async,raw lte1: rcvd OK
00:48:10 lte,async,raw lte1: sent AT+CSQ
00:48:10 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:13 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:13 lte,async,raw lte1: rcvd OK
00:48:13 lte,async,raw lte1: sent AT+CSQ
00:48:13 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:16 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:16 lte,async,raw lte1: rcvd OK
00:48:16 lte,async,raw lte1: sent AT+CSQ
00:48:16 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:19 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:19 lte,async,raw lte1: rcvd OK
00:48:19 lte,async,raw lte1: sent AT+CSQ
00:48:19 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:22 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:22 lte,async,raw lte1: rcvd OK
00:48:22 lte,async,raw lte1: sent AT+CSQ
00:48:22 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:25 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:25 lte,async,raw lte1: rcvd OK
00:48:25 lte,async,raw lte1: sent AT+CSQ
00:48:26 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:28 system,info,account user nemke logged in from 192.168.88.90 via telnet
00:48:29 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:29 lte,async,raw lte1: rcvd OK
00:48:29 lte,async,raw lte1: sent AT+CSQ
00:48:29 lte,async,raw lte1: rcvd +CSQ: 0,99
00:48:32 lte,async,raw lte1: sent AT+EEMGINFO?
00:48:32 lte,async,raw lte1: rcvd OK
00:48:32 lte,async,raw lte1: sent AT+CSQ
00:48:32 lte,async,raw lte1: rcvd +CSQ: 0,99
I didn't change any other jumper on board, exept USB to try other combination.
Where is the problem ?
nemke
Re: RBM33G with RB11e-LTE no connection
Thu Jan 24, 2019 11:44 pm
Anyone ?
I send support file to MT but there is no any reply for 4 business days.
Like to know is it RBM33G damaged so I need to replace it, or it is software bug and can bee solved after update.
Now I am stuck
nemke
Re: RBM33G with RB11e-LTE no connection  [SOLVED]
Mon Feb 11, 2019 9:38 pm
SOLVED
It was problem with LTE reception... Mounting Antenna on R11e-LTE solved problem. Can't bolieve that signal is sooo weak when there is no usage of antenna.
Now work like charm.
Users browsing this forum: No registered users and 22 guests
