digin4
Can the hAP ac² act as a router?
Tue Jan 22, 2019 9:09 pm
Hello, can the hAP ac² act as a router instead of an access point? I want it to act as a DHCP server and use firewall nat rules.
vecernik87
Long time Member
Long time Member
Re: Can the hAP ac² act as a router?  [SOLVED]
Wed Jan 23, 2019 1:59 pm
Yes it can :) any mikrotik running RouterOS can act as router with firewall, NAT, DHCP, Queues, VPN, etc etc..
That is true for every model except CSS range (which feature SwOS)
hAP ac2 actually comes with factory default setting as router+ap. Your WAN will be predefined on eth1 while wifi and eth2-eth5 will work as LAN. You can of course reconfigure it in any way you can imagine.
normis
Wed Jan 23, 2019 2:35 pm
It doesn't need to act, because it already is a router out of the box (and has some firewall and NAT rules pre-configured already, for your convenience).
CZFan
Wed Jan 23, 2019 2:53 pm
Exactly what it is designed for
MTCNA, MTCTCE, MTCRE & MTCINE
Users browsing this forum: No registered users and 15 guests
