tylerbncw
BTest Server & CPU Load
Fri Jan 25, 2019 6:32 pm
Hello all.
I have been testing bandwidth between two Mikrotik CCR1009-8G-1S-1S+ with the use of the BTest function. I have live tested and bench tested two sets of routers. I have been getting speeds that are nowhere close to what they should be. I'm talking 100M over a 1G, 3 foot patch cable. When looking at the CPU load when testing, it appears that core 2 is maxing out at 100% usage. Is this normal? Do I have some some sort of multi-core processing turned off? Any help would be appreciated.
Thanks for your time.
nescafe2002
Long time Member
Long time Member
Re: BTest Server & CPU Load  [SOLVED]
Fri Jan 25, 2019 6:51 pm
You can switch to testing channel to utilize multithreaded btest.
https://mikrotik.com/download/changelog ... lease-tree
What's new in 6.44beta39 (2018-Nov-27 12:14):
*) btest - added multithreading support for both UDP and TCP tests;
tylerbncw
Fri Jan 25, 2019 6:57 pm
Wow, that's perfect. Thanks for the quick response and for your time.
nescafe2002
Long time Member
Long time Member
Fri Jan 25, 2019 7:05 pm
Kudos for the developers :)
Users browsing this forum: No registered users and 20 guests
