wirelessadweb
CRS328-24P-4S+RM SFP
Sun Jan 27, 2019 2:07 pm
Hi Just installed a CRS328-24P-4S+RM and really pleased with its passive PoE and af/at support. In doing some testing though when I attach a SFP+DAC 1M there is no status on the SFP port I have also tried S-RJ01 and denada. I have a 206SP on the other end and it lights up fine.
I scanned the forum and manual and I believe they are not shared ports - is there something I need to set in Router OS? I am booting into Router OS 6.43.8 and have upgraded the firmware.
lapsio
Re: CRS328-24P-4S+RM SFP
Mon Jan 28, 2019 3:27 pm
CRS328-24P-4S+RM ... S-RJ01 ... 206SP
CRS328-24P-4S+
4S+ == 4x SFP+ (10G)
206SP has SFP (1G)
S-RJ01 is SFP (1G)
Here, look up section about using SFP modules compatibility with SFP+ ports:
https://wiki.mikrotik.com/wiki/MikroTik ... lity_table
TL;DR /interface ethernet set X auto-negotiation=off
in theory in both devices, in practice typically setting it on SFP+ side is enough. It's commonly brought up question.
MTCNA, MTCRE, MTCINE
wirelessadweb
Mon Jan 28, 2019 9:39 pm
Hi
Thank you I missed the SFP"+" saw the compatibility was fine hence the confusion. Thank you for taking the time out to point me in the right direction.
lapsio
Tue Jan 29, 2019 12:24 am
Hi
Also if you ever need autoneg enabled for whatever reason on SFP+ port with SFP module, then FS.COM makes magical Generic SFP SX modules that somehow work with MikroTik SFP+ ports even with auto-negotiation on. Unfortunately their copper modules behave just like any other SFP module (require auto-negotiation off)
wirelessadweb
Wed Jan 30, 2019 7:12 am
Thanks again I will keep that in mind
Users browsing this forum: No registered users and 10 guests
