MarcFumi
RouterBOARD 133/C
Tue Mar 13, 2007 8:34 pm
Hi forum!
I have RouterBOARD 133/C for probes...
In this routerboard don't have some modules.. (hotspot for example)
I try to install the modules but nothing.. In log of RouterOS says...
installed (disabled)hotspot-2.9.40.npk
RB133/C is AP Client? this is the problem?
thx
babyface
Tue Mar 13, 2007 9:03 pm
Hi. RB/133C only have RouterOS LEVEL 3 installed. LEVEL 3 is only for CPE.
MarcFumi
Wed Mar 14, 2007 11:10 am
But... I have level 4... i can't use some packages (hotspot,dhcp...)
If i have level4, can i use rb133/C as AP?
thx
normis
Wed Mar 14, 2007 12:57 pm
just go download the missing packages and install them. but be careful, the 133c has little free space, you might have to uninstall some other packages.
MarcFumi
Wed Mar 14, 2007 2:14 pm
I install all packages and enable.. but routerboad have 3812.9 kib (4mb more or less) i think it's low memory for work to AP
normis
Wed Mar 14, 2007 2:25 pm
that is the reasony why it's called CPE. but anyway, you should disable some packages.
jober
Long time Member
Long time Member
Thu Mar 15, 2007 4:04 am
With only one ethernet port and one miniPCI port a CPE is all I would think of using it for.
We only use the rb532's for clients now. We have been slowly moving clients to 5.8Ghz to connect to the towers and then add the 2.4Ghz for hotspot, so the 133c is not to good for clients at this time. But for customers that want service within a hotspot zone the 133c may be what we ship them for self installs. It could work out very nice.
starwing
Thu May 03, 2007 5:03 am
Some RB133 come with L4 license. Are these good as a hotspot AP? How many user can it handle (512k per user)? Any experience to share?
normis
Thu May 03, 2007 8:47 am
the Level4 supports up to 200 active hotspot users. I don't suggest using the RB133c as an AP, or at least limit it to SOHO applications.
karyal
Thu May 03, 2007 2:15 pm
Normis, is it different just disabling or unistalling a packages?
Users browsing this forum: No registered users and 22 guests
