dnetcrawler
DAC cables on CCR1036-12G-4S not working.
Tue Jan 29, 2019 11:46 pm
We've been trying to make the 10GE SFP interface work, but have had no luck. We are using 2 different DAC cables, one of them Mikrotik, and neither work.
The interfaces are configured as 10GE full duplex non-negotiate, but for some reason they default to operating in 1GE rate.
Code: v6.43.8 (stable)
[admin@MikroTik] /interface ethernet> print detail
Flags: X - disabled, R - running, S - slave
12 R name="sfp1" default-name="sfp1" mtu=1500 l2mtu=1580 mac-address=64:D1:54:13:CB:A0 orig-mac-address=64:D1:54:13:CB:A0 arp=enabled arp-timeout=auto loop-protect=off loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m
auto-negotiation=no advertise=1000M-full,10000M-full full-duplex=yes tx-flow-control=off rx-flow-control=off speed=10Gbps bandwidth=unlimited/unlimited
13 R name="sfp2" default-name="sfp2" mtu=1500 l2mtu=1580 mac-address=64:D1:54:13:CB:A1 orig-mac-address=64:D1:54:13:CB:A1 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m
auto-negotiation=no advertise=10M-full,100M-full,1000M-full,10000M-full full-duplex=yes tx-flow-control=off rx-flow-control=off speed=10Gbps bandwidth=unlimited/unlimited
[admin@MikroTik] /interface ethernet> monitor sfp1
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
sfp-module-present: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: (unknown)
sfp-link-length-copper: 7m
sfp-vendor-name: Mikrotik
sfp-vendor-part-number: S+DA0001
sfp-vendor-revision: D
sfp-vendor-serial: SK180322C11659
sfp-wavelength: 3072nm
eeprom-checksum: good
[admin@MikroTik] /interface ethernet> monitor sfp2
status: link-ok
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP-or-SFP+
sfp-connector-type: copper-pigtail
sfp-link-length-copper: 1m
sfp-vendor-name: Amphenol
sfp-vendor-part-number: 604950001
sfp-vendor-revision: A
sfp-vendor-serial: APF11460010RMV
sfp-manufacturing-date: 11-11-18
Cisco Config
service unsupported-transceiver
no errdisable detect cause gbic-invalid
R1-CORE#show int status
Port Name Status Vlan Duplex Speed Type
Te1/1/2 notconnect routed full 10G unknown
Te1/1/3 notconnect 1 full 10G SFP-10GBase-CX1
R1-CORE#show int ten 1/1/2
TenGigabitEthernet1/1/2 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is b090.7ef1.14c8 (bia b090.7ef1.14c8)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is unknown
input flow-control is on, output flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
0 input packets with dribble condition detected
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
0 unknown protocol drops
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
R1-CORE#show int ten 1/1/3
TenGigabitEthernet1/1/3 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is b090.7ef1.149f (bia b090.7ef1.149f)
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-CX1
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Received 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 2 interface resets
mada3k
Re: DAC cables on CCR1036-12G-4S not working.
Wed Jan 30, 2019 6:20 pm
CCR1036-12G-4S is gigabit only - not 10G ports.
Manages some CCR's, RB750Gr3, RB922 and wAP's
dnetcrawler
Wed Jan 30, 2019 6:26 pm
That would explain it....
sebastia
Wed Jan 30, 2019 7:08 pm
for 10g you want to have the "S+" ports
Users browsing this forum: No registered users and 14 guests
