Aznboy1993
CRS305-1G-4S+IN PoE In not working with Ubiquiti US-8-60W
Wed Feb 13, 2019 11:05 am
I recently purchased a CRS305 switch with the intention of going 10GbE for part of my network (server, NAS and main desktop). To that end, everything works great!
I have one hiccup with the setup. My intention is to use the 1GbE port on the CRS305 as an uplink and PoE power to an upstream Ubiquiti US-8-60W switch. Initially, when I first received the CRS305 and set it all up last week, everything worked just fine. I had the CRS305 plugged into port 5 of the US-8-60W (ports 5-8 are PoE capable). The only PoE device attached to the US-8-60W is an Ubiquiti AP (UniFi HD) which is connected to port 8. I am using SwitchOS. Both switches have the latest firmware.
Recently, I unplugged the devices to do some cable management and upon re-plugging everything back in (same setup as before), the CRS305 will not power on via PoE from the US-8-60W. I tried rebooting the US-8-60W, trying different ports and different cables (Cat5e and Cat6a) to no avail. Obviously, the switch powers on and works just fine using the AC adapter. It will also work using a Ubiquiti PoE injector (48V, 0.5A)...but not the US-8-60W.
I am at a lost as to why it initially worked, but will not anymore. Any one have any ideas?
Thanks!
ryanakata
Re: CRS305-1G-4S+IN PoE In not working with Ubiquiti US-8-60W
Thu Mar 07, 2019 10:46 pm
I'm in the same boat as you, however with one odd situation.
Initially out of the box I had to use the AC adapter. I upgraded the firmware on the MikroTik unit to 6.43.8 (I think?) and the switch was able to be powered by the US-8-60w with two DAC cables and a fiber sfp+ module installed.
I upgraded all of my firmware (MikroTik, UniFi) and since then I can no longer power it over the POE IN port. Currently using a random DC power supply I have as I have no idea where the MikroTik one is now. I'd love to be able to get this resolved, but it may be a UniFi issue rather than a MikroTik issue.
Lifz
Wed Mar 20, 2019 2:28 pm
Please send supout file from your devices to support@mikrotik.com.
Bandalo
Wed Apr 17, 2019 1:49 pm
I'm having the same issue. Installed the new switch on POE to my US-8-60W, did all the updates, set it to SwOS, and it worked great for a week. Then last night we had a power outage, and this morning, the MicroTik refuses to work on POE, but works fine with the AC adapter. All my other POE devices work, and I've tried different switch ports and cables.
I also noticed that if i disconnect the DAC cable going to my NAS, the MikroTik will power up and run just fine on POE. If I plug the DAC cable in AFTER it's powered on, it works great too.
It just won't do the initial boot on POE with the DAC cable connected.
flo82
Tue Jul 02, 2019 9:13 pm
any news on this?
I got the same behaviour: I also noticed that if i disconnect the DAC cable going to my NAS, the MikroTik will power up and run just fine on POE. If I plug the DAC cable in AFTER it's powered on, it works great too. It just won't do the initial boot on POE with the DAC cable connected.
hardware CRS305-1G-4S+IN and Ubiquiti US-8-60W with only one DAC cable/device
cdemers
Sat Jul 06, 2019 2:38 am
Sounds like maybe you are using active dac cables and don't have enough wattage with the dac installed to boot. Devices normally need a lot of power for the initial boot (charging capacitors and boot straping), but once running power reduces and you can add additional loads (the dacs). It's possible that if the ports start in a powered down mode and is turning them on too soon in the boot sequence, it goes over amperage and the voltage drops and crashes the cpu/chips locking up. In this case it might be possible for a firmware update to fix it by just adding a delay.
I have never tried to run a sfp switch with just poe, some of those active sfp modules just need too much power. Might be fine for backup power though as long as there is not too much load on the poe.
Just my .02 cents...
Sent from my SM-A520W using Tapatalk
eds89
Mon Jul 08, 2019 10:58 pm
Has anyone received any advice from Mikrotik on this?
I have supported two support request with no response, and am seeing the exact same thing, however with the CRS309, and a 16 port UniFi PoE switch.
I do believe however, that putting one of the UniFi ports into passive 24V poe mode, it works ok, but not with poe+ (802.3af/at).
I have 2x DAC cables (not active as far as I know) and 1x Copper transciever. I have not yet tried booting without cables attached.
eds89
Mon Jul 29, 2019 5:34 pm
Still nothing on this issue?
Very frustrating for me, as one of the main reasons I purchased my switch for my designed deployment, was the PoE capability!
Users browsing this forum: No registered users and 17 guests
