sdespinozar
CCR1009-8G-1S-1S+ CPU NO balancing
Thu Feb 28, 2019 3:14 am
It's a firmware problem or it's a hardware problem.
discard testing the configuration in a CCR-1036 and all good
CPU balancing when using more than 09 CPUs; CCR1009-8G-1S-1S+(graphic attached)
chechito
Re: CCR1009-8G-1S-1S+ CPU NO balancing
Fri Mar 01, 2019 12:32 am
avoid using ether 1 2 3 4 interfaces
use only 5 6 7 8 sfp sfp + interfaces
because of this
https://i.mt.lv/cdn/rb_files/CCR1009-140630151424.pdf
and dont forget to upgrade to 6.43.12 for security reasons
Users browsing this forum: No registered users and 6 guests
