Now I've added a CRS317-1G-16S+, and when I move the transceiver from the CRS326 into the CRS317 it won't link/work.
When I issue the command
Code: Select all
monitor sfp-sfpplus1
Code: Select all
status: no-link
auto-negotiation: done
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-loss: yes
sfp-tx-fault: no
sfp-type: (unknown)
eeprom-checksum: good
eeprom: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
Code: Select all
sfp-type: (unknown)
I have upgraded/updated all devices to v6.44. All devices are fairly new (less than 6 months old.
