Meins
More "Power" for CRS112-8P-4S-IN
Sun Mar 24, 2019 1:59 pm
Hello
The CRS112-8P-2S-In is a wounderfull poe switch and great to build a easy and cheap. But the CPU is not very powerfull. So i only can use them for System up to 30MBit. At the Moment the AP's (Cap AC) have a more powerfull CPU (ARM with 4 Core) then the main. Yes i know it is only a switch but for small Systems it would be great if i have a aio device for Routing, switching with poe etc.
PEter
honzam
Re: More "Power" for CRS112-8P-4S-IN
Sun Mar 24, 2019 2:05 pm
+ 1
LAN, FTTx, Wireless. ISP operator
Steveocee
Sun Mar 24, 2019 3:21 pm
Fast track should see you up to 150Mb
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
Meins
Sun Mar 24, 2019 3:25 pm
Without Fasttrack you will get about 20MBit, with 40MBit because the NAT need a lot of system resourcen. Without NAT then you will get your performance. But i Need the nat for the gateway
Meins
Sun Mar 24, 2019 3:56 pm
And additional 8 Port without poe and a VDSL2 (dual) Interface would be also great
Users browsing this forum: No registered users and 6 guests
