flyingpiglet
hAP AC PoE out on port 5 to power on ip camera
Mon Jun 03, 2019 12:52 pm
Dear friends
can you please advice whether it's possible to power on 802.3af ip camera from hAP AC port 5 if i use 48POW power supply for the router box?
The native power supply (24pow) seems not enough for the camera to switch on from PoE.
Thank you
normis
Re: hAP AC PoE out on port 5 to power on ip camera
Mon Jun 03, 2019 2:05 pm
no, that port only supports passive PoE output, at the same voltage as you input with the DC jack, so most likely camera will not work.
flyingpiglet
Mon Jun 03, 2019 2:56 pm
Sorry, normis
you mean PoE port outputs the same voltage which is on DC input? So if i use 48POW i should have 48v on PoE port. Is that right?
Now i'm using 18pow and the voltage on PoE port seems not enough.
flyingpiglet
Thu Jun 06, 2019 1:23 pm
For those who might be interested - i replaced the 18POW with 48POW for my hAP AC box.
The ip camera (Dahua DH IPC-HDW4631C-A 6MP HD POE) PoE'd from ethernet port 5 works fine now.
krafg
Sun Jun 09, 2019 6:58 pm
Very interesting, I work with Dahua cameras.
Regards.
Users browsing this forum: No registered users and 9 guests
