savage
Mikrotik SFP / Cisco
Thu Jun 06, 2019 12:23 pm
Hi Guys,
Anyone here using the Mikrotik MM / SM SFP modules on Cisco 9200 switches (1G links)?
I know there are IOS commands and what not for the Cisco to "make it work" with 3rd party optics - this doesn't guarantee compatibility though. Just figured I'd ask to see whether I can get confirmation of compatibility from someone, or whether I need to purchase Cisco modules for the switches.
Thnx,
Regards,
Chris
mada3k
Re: Mikrotik SFP / Cisco
Fri Jun 07, 2019 1:45 pm
The magic "service unsupported-transceiver" command
My experience is that regular 1G MM seems to work fine. Copper SFPs with auto-stuff doesn't. Never tested SFP+.
Manages some CCR's, RB750Gr3, RB922 and wAP's
Steveocee
Tue Jun 11, 2019 2:57 pm
Probably not massively helpful for you but I successfully use the Cisco GLC-SX-MM SFP's in all of my MT devices. Dirt cheap on the second hand market as well.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
RackKing
Thu Jun 13, 2019 1:32 pm
Thanks for the tip - very helpful
Users browsing this forum: MSN [Bot] and 17 guests
