joshgambit
hEX S & SFP S-RJ01
Mon Jun 24, 2019 7:19 pm
I just purchased a hEX S & S-RJ01; but I can't seem to get the SFP port to work with my WAN. I'm going directly from a cable modem into the SFP port, but I can't get it to link up. If I put the cable modem cord into ETH1 and change the setting from ETH1 to SFP1, it works. It seems I can only use the SFP port for a LAN port?
Pardon my ignorance; I'm a beginner with this hardware & software.
Thanks,
Josh
Steveocee
Re: hEX S & SFP S-RJ01
Tue Jun 25, 2019 5:30 pm
SFP port can be purposed however you need it to be.
Can you put the SFP into your :AN and connect a PC to it and access the router?
It sounds like hardware issue or negotiation problem between modem and SFP.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
msatter
Tue Jun 25, 2019 5:56 pm
Indeed switch of auto negotiation and set speed to 1Gbit.
Those SFP can generate much heat and in the middle of the thread you see my solution for the hEX-s
viewtopic.php?p=671105
Two RB760iGS (hEX S) in series. One does PPPoE/IKEv2 and the other does the rest of the tasks.
Running:
RouterOS 6.46Beta / Winbox 3.19 / MikroTik APP 1.2.10
Having an Android device, use https://github.com/M66B/NetGuard/releases no root required
joshgambit
Wed Jun 26, 2019 6:24 pm
Okay. Here's what I've done.
SFP Port is going to my computer.
Ether1 is going to the modem.
I'm able to access the internet and the router with no problems.
If I switch it to:
SFP going to the modem
Ether1 going to my computer
I'm unable to access the internet. I've turned off Auto-Negotiation and set the speed to 1Gbit. I've also switched the "Port" setting under Internet in the Quick Set from Eth1 to SPF1. So, what am I doing wrong?
msatter
Wed Jun 26, 2019 11:12 pm
Running:
Users browsing this forum: No registered users and 8 guests
