chitoz
NetInstall RB1100 Kernel Panic
Sat Jul 13, 2019 5:16 am
I have a problem with Mikrotik RB1100
I try Netisntall always appear
Kernel panic - not syncing: Attempted to kill init!
What can I do.?
Thanks, :)
mkx
Re: NetInstall RB1100 Kernel Panic
Sat Jul 13, 2019 12:24 pm
Use another version of netinstall ...
Make sure that no other device is in the same physical network during netinstalling (read: use direst ethernet connection between PC and RB) and make sure you follow all instructions from netinstall manual ... which is vital as netinstall procedure is fairly fragile.
BR,
Metod
Users browsing this forum: No registered users and 19 guests
