Wintel2019
Internet network exchange on lost connection
Thu Jul 18, 2019 11:24 am
On the Routerboard device model RB201 1iL-RM we have two WAN connections and a LAN connection. When it goes down the WAN1 internet connection must automatically switch over to WAN2. When the WAN1 connection is re-established the Router must return to the main internet connection, WAN1. How can I configure it? Is it possible to have a script already working?
Thank you.
cdiedrich
Forum Veteran
Forum Veteran
Re: Internet network exchange on lost connection
Thu Jul 18, 2019 4:28 pm
Look here.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
Wintel2019
Fri Jul 19, 2019 8:29 pm
I followed the guide but I can't get it to work.
You have a backup file for this configuration that you can import.
Thank you so much
Fernando
krafg
Long time Member
Long time Member
Sun Jul 21, 2019 4:12 am
With export command, copy and paste here your configuration (using hide sensitive option).
Regards.
If you want to know my network, you can find it here.
Wintel2019
Mon Jul 22, 2019 9:49 am
# model = 2011iL
# serial number = 762507C3378A
add name=bridge1
set [ find default-name=ether1 ] name=ether1WAN1
set [ find default-name=ether2 ] name=ether2WAN2
set [ find default-name=ether9 ] name=ether9LANlocal
add name=pool1 ranges=192.168.1.2-192.168.1.254
add address-pool=pool1 disabled=no interface=bridge1 name=server1
add bridge=bridge1 interface=ether9LANlocal
add address=192.168.2.99/24 interface=ether1WAN1 network=192.168.2.0
add address=192.168.3.99/24 interface=ether2WAN2 network=192.168.3.0
add address=192.168.1.1/24 interface=ether9LANlocal network=192.168.1.0
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.1 \
netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add check-gateway=ping distance=1 gateway=8.8.8.8 routing-mark=ISP1
add check-gateway=ping distance=2 gateway=208.67.222.222 routing-mark=ISP1
add check-gateway=ping distance=1 gateway=208.67.222.222 routing-mark=ISP2
add check-gateway=ping distance=2 gateway=8.8.8.8 routing-mark=ISP2
add distance=1 dst-address=8.8.8.8/32 gateway=192.168.2.1 scope=10
add distance=1 dst-address=208.67.222.222/32 gateway=192.168.3.1 scope=10
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
set time-zone-name=Europe/Rome
Wintel2019
Wed Jul 24, 2019 6:57 pm
There are changes to be made to the script sent
Users browsing this forum: No registered users and 18 guests
