breizyann
HEX S RB760iGS → console mode...?
Wed Jul 24, 2019 5:27 pm
Hello @all,
I'm new to this forum, so please don't hurry if i don't post my question in the right topic :-)
Recently i owned a: HEX_S/RB760iGS router with one SFP port and also an USB port type A available.
My question is it possible to connect in console/terminal mode using a specific usb adapter...?
Else what solution to connect in console/terminal mode without using an IP adress....
Because if i connect in terminal mode over an IP adress what's happen if i make a mistake in the config?
For me i cut the branch where i'm seating ?
Thank for helping and if possible provide me a secur way to connect in terminal mode on this router.
Kind regards,
Yann
matuss
Re: HEX S RB760iGS → console mode...?
Thu Jul 25, 2019 4:40 pm
It should not be necessary, as Winbox (Mikrotik configuration software) features "Safe mode", see https://wiki.mikrotik.com/wiki/Manual:Console#Safe_Mode (manual is about Console, but it is the same in Winbox also).
But according to viewtopic.php?t=81925 it should work.
mkx
Thu Jul 25, 2019 4:52 pm
You can use Woobm USB gadget to connect to router's console ... I can't vouch that it works with all RB devices but I haven't heard it doesn't either.
BR,
Metod
r00t
Thu Jul 25, 2019 5:52 pm
You can use USB to serial adapter for console, however console will not be spawned on it by default.
So in case where you already have inaccessible device (like after FW misconfiguration) you can't just plug in USB to serial cable and get console, it has to be first configured to run like that.
WOOBM is probably special in some way where ROS automatically spawns new console on it by default (probably using VID/PID or some other ID).
breizyann
Wed Aug 07, 2019 9:52 pm
Hello friends,
I successfuly tested using winbox :-)
Really a nice and useful tool.
Thank @all for your precious answers.
King regards,
Yann
bourneagainsh
Wed Jun 24, 2020 5:47 pm
How or where can you configure the console to be spawned on it by default, please?
r00t
Wed Jun 24, 2020 6:06 pm
First make sure USB adapter is plugged in and visible in system/ports, you can also set baudrate and other options there.
Then go to system/console and add console on that port. This will be remembered as long as you plug in same USB adapter to the same USB port.
bourneagainsh
Wed Jun 24, 2020 7:17 pm
I have FTDI Chip, Null Modem Cable USB - USB NMC-2.5M from "FT232RL"
https://uk.rs-online.com/web/p/interfac ... s/0537420/
This is my output:
[hEX S | RB760iGS] > /system console print
Flags: X - disabled, U - used, F - free
 #   PORT                                                   TERM
 0   serial0                                                vt102
[hEX S | RB760iGS] > /port print
Flags: I - inactive
 #   DEVICE NAME                                     CHANNELS USED-BY                                   BAUD-RATE
 0 I        serial0                                         1                                           auto
 1          usb2                                            1                                           9600
When connected to PC this is dmesg:
[Wed Jun 24 15:03:32 2020] usb 3-1.2: new full-speed USB device number 5 using xhci_hcd
[Wed Jun 24 15:03:32 2020] usb 3-1.2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[Wed Jun 24 15:03:32 2020] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Wed Jun 24 15:03:32 2020] usb 3-1.2: Product: USB Null Modem Cable
[Wed Jun 24 15:03:32 2020] usb 3-1.2: Manufacturer: FTDI
[Wed Jun 24 15:03:32 2020] usb 3-1.2: SerialNumber: FTBF8HE3
[Wed Jun 24 15:03:32 2020] ftdi_sio 3-1.2:1.0: FTDI USB Serial Device converter detected
[Wed Jun 24 15:03:32 2020] usb 3-1.2: Detected FT232RL
[Wed Jun 24 15:03:32 2020] usb 3-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
But still unable to connect :( I have tried the following, but I get no console.
sudo agetty -L 9600 ttyUSB1 vt102
sudo agetty -L 9600 ttyUSB1 linux
I have added the usb2 port to the console (assuming it is the usb2 as it changed from 0 to 1, when I plugged the cable in)
This is the output on print in system-console:
/system console add port=usb2
[hEX S | RB760iGS] /system console>  print
 #   PORT                                                   TERM
 0   serial0                                                vt102
 1 X usb2                                                   vt102
And I can not enable it ...
What am I doing wrong?
r00t
Thu Jun 25, 2020 4:55 pm
This should work, you are not doing anything wrong. Mikrotik can see the serial port but for some reason doesn't want to enable console on it... this never happened to me.
msatter
Thu Jun 25, 2020 5:28 pm
RouterOS 6.47 release notes: *) port - removed serial console port on hEX S
viewtopic.php?f=21&t=161887
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta35 / Winbox 3.27 64bits / MikroTik APP 1.3.15
bourneagainsh
Thu Jun 25, 2020 8:48 pm
https://forum.mikrotik.com/viewtopic.php?f=21&t=161887
So the only way is to get the "Woobm-USB" [https://mikrotik.com/product/woobm]
or this will not work as well since the serial is been removed?
msatter
Thu Jun 25, 2020 8:58 pm
I can't say that and better contact support on support@mikrotik.com this is free and give them a few days time to reply.
Running:
bourneagainsh
Thu Jun 25, 2020 9:07 pm
I have 2 x hEX S,
How can I enable the serial on the other one that is not locked by firewall.
Any idea?
msatter
Thu Jun 25, 2020 9:25 pm
Which version of RouterOS are you using? If you use a version that is lower than 6.47 then the console could work.
We are not the support department of Mikrotik and users of Mikrotik products just like you. There must be a reason Mikrotik disabled the console for the hEX-S in 6.47 which not known to me.
Running:
bourneagainsh
Thu Jun 25, 2020 10:05 pm
Unfortunately I have upgraded to 6.47 (Stable) as soon is it was out ......
bourneagainsh
Thu Jun 25, 2020 10:39 pm
Should have look, hate sending this kind of stuff over the e-mail.
There is a Support Portal to be found here now, for those of you preferring this over sending e-mails ......:
[https://help.mikrotik.com/servicedesk/]
msatter
Fri Jun 26, 2020 11:39 am
There is a Support Portal to be found here:
I prefer e-mail and transport of the e-mail is normally done encrypted.
Running:
bourneagainsh
Fri Jun 26, 2020 3:16 pm
#Woobm-USB
just got it delivered, plugged into the USB got the WoobmAP on, connected to it (hEX S - 6.47 stable)
Got assigned IP address 192.168.4.1, opened web browser and there was the console.
Logged in, and disabled offending firewall rule and all is working again.
msatter
Fri Jun 26, 2020 3:20 pm
#Woobm-USB
That is great news and pleased to read the Woobm helped you out.
Running:
Users browsing this forum: No registered users and 22 guests
