Spaider
hAP ac2 - how to choose PoE input
Fri Aug 09, 2019 7:00 pm
I'm having a hard tying to understand which PoE injector should I use for it? Does it require Mikrotik-branded injector or I can use any 802.3af injector available? Did not anticipated any poblems and bought TP-Link TL-POE150S and it does not work.
andriys
Re: hAP ac2 - how to choose PoE input
Fri Aug 09, 2019 7:16 pm
hAP ac² only supports Passive PoE, so it's not compatible with the type of injector you've bought.
Spaider
Fri Aug 09, 2019 10:02 pm
So, I need 24V passive PoE injector with PSU which provides 18 W or more.
Did I get it right?
andriys
Fri Aug 09, 2019 10:34 pm
Yep, the required voltage to power hAP ac² via PoE-in is 18-28V, so a passive PoE injector with 24V PSU should work just fine. When in doubt, the product page is your best friend: https://mikrotik.com/product/hap_ac2.
Edit: You can actually get yourself just a proper injector, as you should be able to use the standard PSU that was shipped with your device also in conjunction with PoE injector.
Users browsing this forum: No registered users and 12 guests
