Snite
wAP ac LTE kt and external antenna.
Sat Aug 17, 2019 11:40 pm
Hello!
The new wAP ac LTE kit (RBwAPGR-5HacD2HnD&R11e-LTE) is very good,
but I can’t find any information about using it with an external antenna.
Unlike the old wAP LTE kit, the openings for SMA connectors in the enclosure are rectangular,
which means ACSMAUFL will not fit here.
Is there any special pigtail for wAP R ac enclosure?
krafg
Re: wAP ac LTE kt and external antenna.
Sun Aug 18, 2019 4:55 pm
What kind of antenna you will put it?
Snite
Mon Aug 19, 2019 12:39 pm
any directional LTE antenna with a high gain and SMA connectors
krafg
Mon Aug 19, 2019 7:27 pm
Ok, I believe that now I understand. Probably ACSMAUFL are too short to this device, but I'n not sure. You have an unit with the cables to test it?
In theory, you need to do that the image describes.
Regards.
Snite
Mon Aug 19, 2019 10:19 pm
i dont have an unit, just want to buy, but i am not sure about it compatability with ACSMAUFL.
Old wAP LTE Kit has a round holes for it, but in a new wAP ac LTE Kit they have a rectangle shape.
krafg
Re: wAP ac LTE kt and external antenna.  [SOLVED]
Mon Aug 19, 2019 11:58 pm
Sure is beacuse the new unit have 2 Ethernet ports and the space is very little to put 2 RP-SMA connectors (Remember that is necessary also enough space between the holes where puts the connectors or you will brake the plastic). For this reason now the holes are available to do it outside. The only doubt that I have is if the ACSMAUFL are enoughly long to install them.
Regards.
Users browsing this forum: No registered users and 12 guests
