yevpro
LAN Ports issue
Sat Aug 31, 2019 2:48 pm
Hi! Ports on RB952 stopped working. They show no sign of working if i connect the device by by cable to PC or switch. But if i use a cable to connect 2 ports on same device (like eth1 and eth2) they go up and work (like data flowing, dhcp client getting ip address, etc).
What might be a reason?
mkx
Re: LAN Ports issue
Sat Aug 31, 2019 3:00 pm
No sign of working as status lights corresponding to ether ports don't light up or blink .. not even on device on the other end of the cable? And you tried with different devices otherwise known to be flawless?
Or no sign of working as no traffic passes despites status lights indicating link?
BR,
Metod
yevpro
Re: LAN Ports issue
Mon Sep 02, 2019 10:57 am
When i connect eth1 to eth2 of the same troubled device, leds go up, in winbox i see that status of port is running and i can see traffic.
When i connect troubled router to the similar RB952 the led doestn go up, status of port in winbox doesnt change and nothing happens. The same situation is on the working device. When i connect PC - nothing happens as well.
Users browsing this forum: No registered users and 4 guests
