intensex
ltap mini can't use 5v power in
Thu Sep 12, 2019 8:03 am
If use USB 5v power in , the LTE will be disappeared, and noise sound from the router board near the GPS module, it's normal? DC and POE in don't have this problem
mkx
Re: ltap mini can't use 5v power in
Thu Sep 12, 2019 8:31 am
Stated max power consumption is 9W ... which is 1.8A @ 5V. Can your power adapter supply such current? Even micro USB connector (and port) might have hard time to pass such high current.
BR,
Metod
normis
Thu Sep 12, 2019 8:37 am
That's right, try a higher power USB adapter and a better quality cable.
intensex
Thu Sep 12, 2019 3:26 pm
I'm sure the AC adapter support 5v2a and the cable was quality good.
Users browsing this forum: No registered users and 15 guests
