MUM Europe 2020
easyyu
How to add external antenna on hAP Light smips (RB-941-2nd)
Tue Dec 17, 2019 4:47 am
I searched this forum and I coudnt finf neither one complete tutorial how to modify motherboard to add the external connector with antenna for this router.
All the pic in threads are dead links.
Only thing what I coud find are these two video, but It is not clear do I need to do this for both antenna or just one, like in video.
He even did something on left antenna, but as I undrstand (I do not understand his language) he decided that it is better to do with another what he showing in video.
https://www.youtube.com/watch?v=Rxe1g74t0BE
In second video he pulling down capacitors (I think) from both antenna.
Is this a correct way?
https://www.youtube.com/watch?v=alHn2XZLgVI
Can someone gude me how to make this modifiaction?
My board is:
Thx
Zacharias
Re: How to add external antenna on hAP Light smips (RB-941-2nd)
Tue Dec 17, 2019 11:53 pm
Why do you want to make that modification ? :?
easyyu
Wed Dec 18, 2019 2:51 am
Because the wifi signal is terrible!
I can not watch the youtube video after 3 walls (of 40cm) diagonally on 15m.
InoX
Wed Dec 18, 2019 6:28 pm
Nothing work reliable after 3 walls. Ad a second router.
easyyu
Wed Dec 18, 2019 9:53 pm
With another TP Link router, I have full signal..and it spread the signal till midle of street, so I do not agree with u!
Anyone with right way to solder the pigtail cable?
r00t
Wed Dec 18, 2019 10:02 pm
I would not solder cable directly to the pcb. Instead get u.fl PCB mount connector, remove the two SMDs that are in the way and solder connector there instead. Seems like there is footprint for it on the PCB (probably used during testing, then bridged by SMDs in production) so it should fit right in. Then use normal u.fl to SMA or N pigtail like for other routerboards.
Zacharias
Wed Dec 18, 2019 10:40 pm
Then why did you change that TP Link ?
easyyu
Thu Dec 19, 2019 2:20 am
Thx for replay.
Then your solution is almost same as on this video:
Only difference is that you proposing the connector and the guy did it with direct soldering on mainboard.
Zacharias
Thu Dec 19, 2019 2:50 am
I hope you have better soldering skills...
kraic
Tue Jan 14, 2020 8:07 pm
How to enable these connectors:
https://ibb.co/87FFBYH
Users browsing this forum: No registered users and 49 guests
