MUM Europe 2020
jdmarti1
Mon May 07, 2007 4:59 pm
If it is a standard install - then you can use neighbor viewer and mac-telnet in. No IP required. Username is admin and no password. If that fails you can look on MT's website and get Net Install - follow the directions. You will have to have a serial cable - unless it is set to boot ethernet, but worth a try before you buy one.
I think my head is gonna explode!!!
usrox
Wed May 09, 2007 7:36 pm
Hello, if you want to reset your routerboard configuration you can done it by shorting the JP3 (RB100 series) or JP1 (RB500 series).
Users browsing this forum: No registered users and 35 guests
