Acryli
RBM33G - mPCIe ports
Wed Jan 08, 2020 2:09 pm
Hello
I have 2 questions about the RBM33G and especially it's mPCIe/M.2 ports.
https://mikrotik.com/product/rbm33g#fnd ... ifications
1. If I understand right, there is an USB 2 bus present on port mPCIe#0 & mPCIe#1 (if jumper accordingly set of course), but is there a PCIe bus connected to both ports also???
2. The M.2 port has exclusively a PCIe bus, no USB at all, right?
Thank you
SiB
Forum Veteran
Forum Veteran
Re: RBM33G - mPCIe ports
Wed Jan 08, 2020 2:28 pm
M.2 is only M.2 port.
https://i.mt.lv/cdn/rb_files/RBM33-1565865697.png
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on ?? ?? 202?
Acryli
Wed Jan 08, 2020 2:37 pm
Yes I know that diagram, but it's c*** I don't trust it because:
1. It's clearly stated that M.2 slot has a PCIe bus. But the "miniPCIe slot 2" there is nothing indicating what that line to the SoC is about (we could thinks it's a PCIe also, but not sure. "miniPCIe" is a connector specification, not a bus!!!).
2. SIM slot 2 & 1 are connected to the SoC according to that diagram, which is actually totally false because it has nothing to do with the SoC, it's electrically connected directly to the corresponding mPCIe slot.
In other words, I don't trust it.
Acryli
Wed Jan 08, 2020 2:41 pm
You mean PCIe bus?
Because M.2 specifications defines PCIe bus and/or USB2/3, I2C,...
Saying M.2 is only M.2, is actually not really clear. But I assume you want to say "PCIe bus only" right?
SiB
Forum Veteran
Forum Veteran
Thu Jan 09, 2020 4:38 am
You mean PCIe bus?
MediaTek MT7621A: https://www.mediatek.com/products/homeN ... /mt7621n-a give info:
  • PCI-Express: Host(3x) but MikroTik give info about 2x
  • USB: USB 3.0 (1x), USB 2.0 (1x)
  • Flash: SPI, SLC NAND
  • embedded 5p GbE Switch
STORAGE
viewtopic.php?f=3&t=134737&p=723757&hilit=m33g#p723757
Now you should see that it's just work for ssd drive.
Connection Diagram
In HiRes photo https://i.mt.lv/cdn/rb_images/1722_hi_res.png are 3x mPCIe like MediaTek describe.
QuickGuide > USB Jumper > I change the queue of original sentence.
Jumper ON:
When loaded, the jumper enables the USB 3.0 port.
Normally you can use the LTE modem in the J8 (lefthand side) slot, and use a 802.11 wireless card in the J10 slot. In this case, you can leave the jumper on, as most
wireless cards operate on a PCI express.
Jumper OFF:
Remove the jumper to switch the USB 2.0 lines to the J10 (central) miniPCIe slot (USB 3.0 lines remain enabled to the USB port).
This is required if you need to use two cellular modems in the device.
Removing the jumper enables the use of a secondary cellular modem in the central J10 slot, but disables the USB 2.0 functionality of the USB port, while USB 3.0 can still be used on the USB port.
Summary:
  • J8 = PCIe 0 = Left = LTE normal
  • J10 = PCIe 1 = Center = WiFI normal or LTE
  • J400 = PCIe 2 = Right = M.2 slot
  • USB: 2.0+3.0 or only 3.0
Your Diagram with some change's:
Acryli
Fri Jan 10, 2020 3:05 pm
Ok thank you.
andryan
Tue Mar 10, 2020 8:31 pm
Hi, does this mean the sim card slots are not switchable with 1 LTE mini-PCIe?
SiB
Forum Veteran
Forum Veteran
Tue Mar 10, 2020 11:10 pm
andryan
"switchable " SIM Slot are in SXTR/LtAP/LtAP mini . Not here .
andryan
Wed Mar 11, 2020 9:31 am
andryan
Thanks for the confirmation, SiB!
Users browsing this forum: doush, IPtrans and 18 guests
