in the beginning i only had a Internet Account with 200Mbit , and the router was able to handle that very fine.
then i get a 500Mbit account speed fluctuates 350-500 Mbit , but i thougt that was related to my Internet Provider.
Since a Week i now have a 1000Mbit Internet Connection, and the Speed again fluctuates between 350-650 Mbits
so for testing i put a direct connection to my Cable Modem , and directly connected i get a very Stable speed near 950 MBit
over the time i had a relative complicated config in the router, but for testing i have resettet everything
started with a Plain config (not default config)
only 2 Ports (eth6 and eth8) and routing (not switching) between them
but also very slow speed (fast path is active)
Speed with RB3011
Speed direkt to Modem
Code: Select all
[admin@MikroTik] > export compact hide-sensitive
# feb/24/2020 12:42:52 by RouterOS 6.47beta35
# software id = [xxx]
# model = RouterBOARD 3011UiAS
# serial number = [xxx]
set [ find default-name=sfp1 ] disabled=yes
add interface=all
add address=10.31.45.1/24 interface=ether6 network=10.31.45.0
add address=172.31.50.1/24 interface=ether8 network=172.31.50.0
set servers=1.1.1.1
add distance=1 gateway=10.31.45.254
/system clock
/system package update
set channel=testing
/system routerboard settings
btw. for Forum Moderators , i wanted to reset my Password in the Forum here
but if i try to set a new password i allways get a "Server Error 500"
