feovo
POE Problem with Omnitik 5ac
Wed Mar 25, 2020 12:14 am
hi
I buy one omnitik 5 ac and 4 units of SXT 5 ac. pluged in poe in 1st port of omnitik and its works fine, but when i pluged the eathernet cable (1 meter) from omnitik to SXT 5 there is no Power ,
try all 4 sxt units and its same no power, but if i plug poe direct from adapter sxt works fine.running latest ROS , and powering omnitik with 48v 2A cisco power adapter. please help to sort this out.
cdemers
Re: POE Problem with Omnitik 5ac
Wed Mar 25, 2020 12:20 am
There is two different models, did you purchase the poe model?
Sent from my SM-A520W using Tapatalk
feovo
Wed Mar 25, 2020 12:23 am
Really i was not aware of that how i can check that ?
feovo
Wed Mar 25, 2020 2:48 pm
Please help me .
how i can identify that i have poe version or not , because on mikrotik website manual says omnitik is with poe output.
matiss
Re: POE Problem with Omnitik 5ac  [SOLVED]
Wed Mar 25, 2020 3:03 pm
By the name/product code - /system routerboard print
RBOmniTikU-5HnD - OmniTIK 5 whitout PoE
RBOmniTikUPA-5HnD - OmniTIK 5 PoE with PoE
RBOmniTikG-5HacD - OmniTIK 5 ac whitout PoE
RBOmniTikPG-5HacD OmniTIK 5 PoE ac with PoE
feovo
Wed Mar 25, 2020 10:45 pm
i was not aware of this thing so i buy
is there any solution or i have to put a jumper from Poe in to lan ports for power up my SXT 5ac units.
mistry7
Wed Mar 25, 2020 11:16 pm
Send back and buy needed device
Users browsing this forum: No registered users and 82 guests
