adambogdan
Bridge between Wifi and LAN + HW for that
Wed Mar 25, 2020 5:28 pm
Hi
I have a small knowledge about Mikrotik devices so maybe someone could point me in proper direction ;)
I need to do a bridge between Wifi interface and Ethernet (LAN) interfaces - wifi side will be connected to other AP
From my small knowledge it should be fairy easy to do on MT - connect to AP, create a bridge and attach wifi and ethernet
interfaces to the bridge - if I'm wrong please correct me.
What I need is a hardware with 2 ethernet ports and - of course - wifi 2.4ghz
I don't need anything fancy or something from the top shelf ;) - I found this - https://mikrotik.com/product/RBmAP2nD -
it has wifi and exactly 2 ethernet ports - just as I need :)
Will this be sufficient for my requirements ? (to connect to AP and create a bridge)
nickshore
Re: Bridge between Wifi and LAN + HW for that  [SOLVED]
Wed Mar 25, 2020 6:38 pm
Yes you can use the mAP2nD for that
1) make a bridge
2) put all 3 ports in the bridge
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
adambogdan
Wed Mar 25, 2020 10:45 pm
Thanks a lot for confirmation nickshore :D
Users browsing this forum: No registered users and 91 guests
