blackbox100
CRS354 not full gigabit on ethernet ports
Thu Mar 26, 2020 11:52 am
Hi All, is anyone experiencing the same issue
when testing we only get around 800/800 on gigabit ports
it looks like the same issues, as when the crs326 first came out, it couldn't do gigabit either, not before after many beta releases?
why on earth does the new crs354 suffer the same problem, is it because its a MIPSBE processor, rather than the ARM Processor on the CRS326
please fix this soon, because I just bought 20 x CRS354 switches to implement, but for now can't use them, because they don't offer full gigabit connectivity on ether net ports?
sincerely
Carsten Larsen
Denmark
EdPa
Re: CRS354 not full gigabit on ethernet ports
Thu Mar 26, 2020 12:19 pm
Please describe in more detail how did you test the throughput on the switch - share some basic network diagram, the actual test results (as a screenshot or terminal output) and the CRS354 configuration export.
blackbox100
Thu Mar 26, 2020 3:37 pm
Hi Edpa
the basic network is this
CRS1036-8G-2S+ (10G internet connection) ---------> CRS317 Core Switch ---------> CRS354 (user switch)
All the devices are connected together by DAC Cables. and are linking with 10G
I have MacBook connected directly to the CRS354 and by doing a speedtest, I only reach about 711/744Mbps
See Screenshot
If I connect the MacBook to the following setup
CRS1036-8G-2S+ (10G internet connection) ---------> CRS317 Core Switch ---------> CRS326 (user switch)
I get speedtest of 940/940Mbps, this I reproduced several times, and I have about 300 x CRS326 in my network, so I´m well wandered in the switch.
I have about 6000 users, which all are connected to the CRS326 Switched, and no-one has trouble reaching speeds of around 950/950Mbps
The setup is the same, the only difference is the end user switch being either the CRS354 or the CRS326
here is the export of the CRS354, and I will post one for the CRS326 so compare
CRS354 Config
# mar/26/2020 14:27:36 by RouterOS 6.47beta49
# software id = 79G8-8TJW
# model = CRS354-48G-4S+2Q+
# serial number = B8450B60831D
add fast-forward=no name=bridge1 protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] loop-protect=on
set [ find default-name=ether2 ] loop-protect=on
set [ find default-name=ether3 ] loop-protect=on
set [ find default-name=ether4 ] loop-protect=on
set [ find default-name=ether5 ] loop-protect=on
set [ find default-name=ether6 ] loop-protect=on
set [ find default-name=ether7 ] loop-protect=on
set [ find default-name=ether8 ] loop-protect=on
set [ find default-name=ether9 ] loop-protect=on
set [ find default-name=ether10 ] loop-protect=on
set [ find default-name=ether11 ] loop-protect=on
set [ find default-name=ether12 ] loop-protect=on
set [ find default-name=ether13 ] loop-protect=on
set [ find default-name=ether14 ] loop-protect=on
set [ find default-name=ether15 ] loop-protect=on
set [ find default-name=ether16 ] loop-protect=on
set [ find default-name=ether17 ] loop-protect=on
set [ find default-name=ether18 ] loop-protect=on
set [ find default-name=ether19 ] loop-protect=on
set [ find default-name=ether20 ] loop-protect=on
set [ find default-name=ether21 ] loop-protect=on
set [ find default-name=ether22 ] loop-protect=on
set [ find default-name=ether23 ] loop-protect=on
set [ find default-name=ether24 ] loop-protect=on
set [ find default-name=ether25 ] loop-protect=on
set [ find default-name=ether26 ] loop-protect=on
set [ find default-name=ether27 ] loop-protect=on
set [ find default-name=ether28 ] loop-protect=on
set [ find default-name=ether29 ] loop-protect=on
set [ find default-name=ether30 ] loop-protect=on
set [ find default-name=ether31 ] loop-protect=on
set [ find default-name=ether32 ] loop-protect=on
set [ find default-name=ether33 ] loop-protect=on
set [ find default-name=ether34 ] loop-protect=on
set [ find default-name=ether35 ] loop-protect=on
set [ find default-name=ether36 ] loop-protect=on
set [ find default-name=ether37 ] loop-protect=on
set [ find default-name=ether38 ] loop-protect=on
set [ find default-name=ether39 ] loop-protect=on
set [ find default-name=ether40 ] loop-protect=on
set [ find default-name=ether41 ] loop-protect=on
set [ find default-name=ether42 ] loop-protect=on
set [ find default-name=ether43 ] loop-protect=on
set [ find default-name=ether44 ] loop-protect=on
set [ find default-name=ether45 ] loop-protect=on
set [ find default-name=ether46 ] loop-protect=on
set [ find default-name=ether47 ] loop-protect=on
set [ find default-name=ether48 ] loop-protect=on
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
/ip hotspot profile
/system logging action
add name=dude remote=192.168.23.5 target=remote
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge1 interface=ether1 pvid=68
add bridge=bridge1 interface=ether2 pvid=68
add bridge=bridge1 interface=ether3 pvid=68
add bridge=bridge1 interface=ether4 pvid=68
add bridge=bridge1 interface=ether5 pvid=68
add bridge=bridge1 interface=ether6 pvid=68
add bridge=bridge1 interface=ether7 pvid=68
add bridge=bridge1 interface=ether8 pvid=68
add bridge=bridge1 interface=ether9 pvid=68
add bridge=bridge1 interface=ether10 pvid=68
add bridge=bridge1 interface=ether11 pvid=68
add bridge=bridge1 interface=ether12 pvid=68
add bridge=bridge1 interface=ether13 pvid=68
add bridge=bridge1 interface=ether14 pvid=68
add bridge=bridge1 interface=ether15 pvid=68
add bridge=bridge1 interface=ether16 pvid=68
add bridge=bridge1 interface=ether17 pvid=68
add bridge=bridge1 interface=ether18 pvid=68
add bridge=bridge1 interface=ether19 pvid=68
add bridge=bridge1 interface=ether20 pvid=68
add bridge=bridge1 interface=ether21 pvid=68
add bridge=bridge1 interface=ether22 pvid=68
add bridge=bridge1 interface=ether23 pvid=68
add bridge=bridge1 interface=ether24 pvid=68
add bridge=bridge1 interface=ether25 pvid=68
add bridge=bridge1 interface=ether26 pvid=68
add bridge=bridge1 interface=ether27 pvid=68
add bridge=bridge1 interface=ether28 pvid=68
add bridge=bridge1 interface=ether29 pvid=68
add bridge=bridge1 interface=ether30 pvid=68
add bridge=bridge1 interface=ether31 pvid=68
add bridge=bridge1 interface=ether32 pvid=68
add bridge=bridge1 interface=ether33 pvid=68
add bridge=bridge1 interface=ether34 pvid=68
add bridge=bridge1 interface=ether35 pvid=68
add bridge=bridge1 interface=ether36 pvid=68
add bridge=bridge1 interface=ether37 pvid=68
add bridge=bridge1 interface=ether38 pvid=68
add bridge=bridge1 interface=ether39 pvid=68
add bridge=bridge1 interface=ether40 pvid=68
add bridge=bridge1 interface=ether41 pvid=68
add bridge=bridge1 interface=ether42 pvid=68
add bridge=bridge1 interface=ether43 pvid=68
add bridge=bridge1 interface=ether44 pvid=68
add bridge=bridge1 interface=ether45 pvid=68
add bridge=bridge1 interface=ether46 pvid=68
add bridge=bridge1 interface=ether47 pvid=68
add bridge=bridge1 interface=ether48 pvid=68
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=sfp-sfpplus2
add bridge=bridge1 interface=sfp-sfpplus3
add bridge=bridge1 interface=sfp-sfpplus4
/interface bridge vlan
add bridge=bridge1 tagged=\
sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,bridge1 vlan-ids=10
sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,bridge1 vlan-ids=11
sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,bridge1 vlan-ids=68
add address=192.168.2.100/22 interface=vlan10 network=192.168.0.0
set servers=8.8.8.8
add distance=1 gateway=192.168.0.1
/snmp
set contact="Carsten Larsen" enabled=yes location="Norgesgade 10"
/system clock
set time-zone-name=Europe/Copenhagen
/system identity
set name=CRS354-TEST
/system logging
add action=dude prefix=01NORG10 topics=critical
add action=dude prefix=01NORG10 topics=error
add action=dude prefix=01NORG10 topics=info,!interface
add action=dude prefix=01NORG10 topics=warning
/system ntp client
set enabled=yes primary-ntp=213.83.176.71
/system package update
set channel=testing
/system routerboard settings
set boot-os=router-os
#error exporting /system swos
/system watchdog
set ping-timeout=5m watch-address=192.168.23.1
/tool romon
set enabled=yes
CRS326 Config
# mar/26/2020 14:34:40 by RouterOS 6.45.3
# software id = WGZ2-2H8D
# model = CRS326-24G-2S+
# serial number = 94550BCB9106
set [ find default-name=ether1 ] loop-protect=on loop-protect-disable-time=6h \
speed=100Mbps
set [ find default-name=ether2 ] loop-protect=on speed=100Mbps
set [ find default-name=ether3 ] loop-protect=on loop-protect-disable-time=6h \
speed=100Mbps
set [ find default-name=ether4 ] loop-protect=on loop-protect-disable-time=6h \
speed=100Mbps
set [ find default-name=ether5 ] loop-protect=on loop-protect-disable-time=6h \
speed=100Mbps
set [ find default-name=ether6 ] loop-protect=on loop-protect-disable-time=6h \
speed=100Mbps
set [ find default-name=ether7 ] loop-protect=on loop-protect-disable-time=6h \
speed=100Mbps
set [ find default-name=ether8 ] loop-protect=on speed=100Mbps
set [ find default-name=ether9 ] loop-protect=on loop-protect-disable-time=6h \
speed=100Mbps
set [ find default-name=ether10 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether11 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether12 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether13 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether14 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether15 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether16 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether17 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether18 ] loop-protect=on speed=100Mbps
set [ find default-name=ether19 ] loop-protect=on speed=100Mbps
set [ find default-name=ether20 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether21 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether22 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether23 ] loop-protect=on loop-protect-disable-time=\
6h speed=100Mbps
set [ find default-name=ether24 ] comment=RPI loop-protect=on \
loop-protect-disable-time=6h speed=100Mbps
set [ find default-name=sfp-sfpplus1 ] speed=10Gbps
set [ find default-name=sfp-sfpplus2 ] speed=10Gbps
/interface vlan
set 0 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 1 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 2 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 3 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 4 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 5 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 6 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 7 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 8 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 9 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 10 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 11 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 12 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 13 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 14 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 15 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 16 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 17 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 18 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 19 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 20 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 21 egress-rate=225.0Mbps ingress-rate=400.0Mbps
set 22 egress-rate=225.0Mbps ingress-rate=400.0Mbps
add name=backbone
/ip hotspot profile
add bridge=bridge1 interface=ether1 pvid=88
add bridge=bridge1 interface=ether2 pvid=88
add bridge=bridge1 interface=ether3 pvid=88
add bridge=bridge1 interface=ether4 pvid=88
add bridge=bridge1 interface=ether5 pvid=88
add bridge=bridge1 interface=ether6 pvid=88
add bridge=bridge1 interface=ether7 pvid=88
add bridge=bridge1 interface=ether8 pvid=88
add bridge=bridge1 interface=ether9 pvid=88
add bridge=bridge1 interface=ether10 pvid=88
add bridge=bridge1 interface=ether11 pvid=88
add bridge=bridge1 interface=ether12 pvid=88
add bridge=bridge1 interface=ether13 pvid=88
add bridge=bridge1 interface=ether14 pvid=88
add bridge=bridge1 interface=ether15 pvid=88
add bridge=bridge1 interface=ether16 pvid=88
add bridge=bridge1 interface=ether17 pvid=88
add bridge=bridge1 interface=ether18 pvid=88
add bridge=bridge1 interface=ether19 pvid=88
add bridge=bridge1 interface=ether20 pvid=88
add bridge=bridge1 interface=ether21 pvid=88
add bridge=bridge1 interface=ether22 pvid=88
add bridge=bridge1 interface=ether23 pvid=88
add bridge=bridge1 interface=ether24 pvid=88
set discover-interface-list=backbone
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,bridge1 vlan-ids=10
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,bridge1 vlan-ids=11
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,bridge1 vlan-ids=88
add address=192.168.2.40/22 interface=vlan10 network=192.168.0.0
set servers=8.8.8.8
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/snmp
set contact="Carsten Larsen" enabled=yes trap-generators=\
temp-exception,temp-exception
/system clock
/system identity
set name=02HVEEN17
/system logging
add topics=interface
add action=dude prefix=02HVEEN17 topics=critical
add action=dude prefix=02HVEEN17 topics=error
add action=dude prefix=02HVEEN17 topics=info,!interface
add action=dude prefix=02HVEEN17 topics=warning
/system ntp client
/system watchdog
/tool graphing interface
add
/tool romon
set enabled=yes
Perhaps you can find the missing piece, to why the CRS354 won't give full gigabit.
I remember when the CRS326 came out, it had the exact same problem, which was resolved after a few months, but I didn't expect the CRS354 to have the same issues
I have just purchased 15 X CRS354 that I need to put into use very soon, but I can't as they are right now, because my users will complain of only getting 700´ish Mbps
If you need further info, please let me know, I have the setup running in my lab, so I can test further
Sincerely Carsten Larsen
EdPa
Mon Mar 30, 2020 9:29 am
Configuration wise, cannot see any issues on the CRS354 device. I would only recommend enabling RSTP or MSTP, but this should not affect the throughput if there is no active loop. But on the CRS326 device, don't the ingress and egress rate properties limit the throughput?
Have you checked if there are any Ethernet errors on CRS354 or CRS317 devices?
Please run the tests again using the same client on CRS326 and CRS354 devices and create supout.rif files after the tests are finished on both devices. Please report this and attach the supout.rif files on https://help.mikrotik.com/servicedesk/
blackbox100
Mon Mar 30, 2020 1:39 pm
you are right the egress rate and ingress rate is enabled on the crs326, I will disable it for the test, and send you both support files after the speedtest is done
there are no ethernet errors on either switches
will send you the files in 10 minutes
sincerely
Carsten
blackbox100
Mon Mar 30, 2020 2:07 pm
files sent
Users browsing this forum: No registered users and 17 guests
