Fable92
R11e-2HPnD doesn't create wlan1 interface on RBM33G
Thu May 21, 2020 9:34 am
I have a RBM33G with RouterOS version 6.46.5.
I have installed a module R11e-2HPnD on the central slot and a 4G module from Sierra Wireless on the other slot.
The problem is: sometimes, when I reboot the router or when I power down/up, the "wlan1" interface is not present.
After some reboots, it comes back visible.
Why?
Is there a way to check the firmware version of the wireless module?
Could be an incompatibility between RouterOS version and module?
The wlan1 interface must be created automatically at startup, right?
Thank you
krafg
Re: R11e-2HPnD doesn't create wlan1 interface on RBM33G
Fri May 22, 2020 4:47 am
Remove the jumper near of USB port.
Regards
If you want to know my network, you can find it here.
Users browsing this forum: No registered users and 43 guests
