looking to buy hAP ac³ LTE6 kit,
hAP will be in Faraday cage so i need to connect LTE modem with externa antenna via SMA connector.
Does hAP have SMA connector for LTE modem?
Hi!Yes, to LTE module attach 2x ACSMAULF. On back side of hAP, you can do the holes for the connectors.
In my case I RMA a LtAP (not mini) with 4 holes on his case without problems. Of course the holes correctly made on correctly places.Hi!Yes, to LTE module attach 2x ACSMAULF. On back side of hAP, you can do the holes for the connectors.
This is a good offer, but what about the device warranty then?
