Jirka69
E3372h-320 USB/lte1 problems constantly LTE1 link up-down
Wed Jun 10, 2020 9:26 am
Hello.
Please help. Huawei E3372h-320 LTE USB Stick is constantly logging in and out and is therefore non-functional. Is there any solution please ??
I also tried an active USB-2 HUB - it didn't help.
Here is an extract from the log after turning on the RB:
# jan/ 2/1970 0:31:15 by RouterOS 6.47
# software id = HA5I-SUXI
00:00:14 system,info router rebooted
00:00:16 interface,info ether2 link up (speed 100M, full duplex)
00:00:24 system,info,account user admin logged in from 00:13:3B:9B:97:0C via winbox
00:00:58 system,info,account user admin logged in from 00:13:3B:9B:97:0C via winbox
00:01:00 system,info,account user admin logged out from 00:13:3B:9B:97:0C via winbox
00:01:54 interface,info lte1 link up
00:01:54 interface,info lte1 link down
00:01:58 interface,info lte1 link up
00:01:58 interface,info lte1 link down
00:02:02 interface,info lte1 link up
00:02:02 interface,info lte1 link down
00:02:04 interface,info lte1 link up
00:02:04 interface,info lte1 link down
00:02:06 interface,info lte1 link up
00:02:06 interface,info lte1 link down
00:02:08 interface,info lte1 link down
00:02:10 interface,info lte1 link up
00:02:10 interface,info lte1 link down
00:02:12 interface,info lte1 link down
00:02:14 interface,info lte1 link up
00:02:14 interface,info lte1 link down
00:02:16 interface,info lte1 link down
00:02:17 interface,info lte1 link up
00:02:17 interface,info lte1 link down
00:02:18 dhcp,info dhcp-client on lte1 got IP address 192.168.8.107
00:02:19 interface,info lte1 link down
00:02:20 dhcp,info dhcp-client on lte1 lost IP address 192.168.8.107 - lease stopped locally
00:02:22 interface,info lte1 link up
00:02:22 interface,info lte1 link down
00:02:22 dhcp,info dhcp-client on lte1 got IP address 192.168.8.107
00:02:24 interface,info lte1 link down
00:02:24 dhcp,info dhcp-client on lte1 lost IP address 192.168.8.107 - lease stopped locally
00:02:26 interface,info lte1 link up
00:02:26 interface,info lte1 link down
00:02:27 dhcp,info dhcp-client on lte1 got IP address 192.168.8.107
00:02:29 interface,info lte1 link down
Thank you very much for your help.
mbovenka
Re: E3372h-320 USB/lte1 problems constantly LTE1 link up-down
Wed Jun 10, 2020 9:39 am
I have the same stick, and it does the same thing. When you look at the USB resources, it's flipping between USB storage device and LTE modem. I think it's trying to offer its builtin 'driver CD' flash to the Mikrotik, like it does to Windows machines (where it works fine) on first connect, and the 'Tik can't deal with that.
But I haven't been able to make it stop and just function as an LTE modem. If anyone has been able to get it to work, I'd be very interested as well!
krafg
Long time Member
Long time Member
Wed Jun 10, 2020 9:59 am
What RouterBOARD are you using?
Regards.
If you want to know my network, you can find it here.
mbovenka
Wed Jun 10, 2020 10:43 am
Same behavior on a hAP AC and a CCR1036-8G-2S+. The hAP is at 6.46.4 and the CCR at 6.46.1.
Jirka69
Wed Jun 10, 2020 11:11 am
Regards.
RB952Ui-5ac2nd
SiB
Wed Jun 10, 2020 11:51 am
and what firmware & webui version you use at e3372 ?
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
At vacation until 15.jan.2021
mbovenka
Wed Jun 10, 2020 12:14 pm
WebUI:
Software version 10.0.3.1(H192SP1C983)
Web UI version WEBUI 10.0.3.1(W13SP2C7110)
Firmware: 22.001.34.01.03
Jirka69
Wed Jun 10, 2020 12:18 pm
Configuration file version E3372h-320-CUST 10.0.3.1 (C965)
Current version 10.0.3.1 (H192SP2C983)
WEBUI 10.0.3.1(W13SP2C7201)
Hardware version CL4E3372HM
Jirka69
Thu Jun 11, 2020 2:37 pm
Hello.
So I tried to use version 7.0beta8 and everything is OK !!! The web interface with settings and sending of SMS is even functional. Fast download test - 70 Mbit / s. So for me - solved :lol: :lol: :lol:
mbovenka
Thu Jun 11, 2020 4:25 pm
Hello.
That's good news! Time to upgrade my CCR to 7.0 then...
yup80
Thu Jun 11, 2020 5:28 pm
Same buggy behavior on E3372h-320 with Mikrotik
Modem:
10.0.3.1(H192SP2C983)
WEBUI 10.0.3.1(W13SP1C7702)
Mikrotik:
Factory Firmware 6.44,
Current Firmware 6.45.3
After upgrade to 6.47 not working too :(
On Linux Gnome 3.36 all working fine
SiB
Fri Jun 12, 2020 2:51 pm
you have a lte1 flapping interface.
Please check when lte1 is down if usb device is still detected in system \ resource \ usb ?
You use HiLink mode with dhcp-client at lte1 then what show you his GUI when you connect to him ? Means, uptime and session uptime or maybe you have some custom firmware ?
In all my e3372 I reflash the firmware at versions 22.333.01.00.00 with 17.100.18.03.143 but this is my responsibility to do that staff go grab features like DMZ, Change LAN IP and have API for SMS... I not know versions of firmware.
mbovenka
Fri Jun 12, 2020 5:29 pm
Like I said earlier, when the link is flapping it's alternating between two USB IDs in USB resources, one for a storage device and one for an LTE modem. When in 'modem' mode the link is up, when in 'storage' mode it's down.
It probably needs an MBIM driver to function (which is what gets installed as a service under Windows when you install the drivers off the internal 'driver CD' flash in the unit). It works under RouterOS 7beta8 (which does have MBIM drivers, whereas ROS6 does not), as both @Jirka69 and myself have tested.
SiB
Fri Jun 12, 2020 8:23 pm
Then please do a supout.rif with that situation and send them to MikroTik support.
gtk
Tue Jun 16, 2020 11:26 pm
I've experiencing same issue as described above.
hAP ac 6.47 (stable)
Huawei E3272h identified as:
0x12d1
0x14db/0x1f01
Upgrade to beta version is not a solution for me.
SiB
Wed Jun 17, 2020 8:26 pm
Then do the same, contact to MikroTik Support.
gtk
Wed Jun 17, 2020 8:40 pm
Already done ;) Thank You.
dilu
Sun Jul 05, 2020 11:56 pm
Any feedback from Mikrotik support?
Just bought hap ac lite and the same problem.
Looking and System->Resources->USB the modem disappear when lte1 is down and appear in few seconds again.
My assumption is that the problem with USB Power, but I don't know how to check it.
Very upset if this is the case as I just sold my RB951Ui-2HnD (where it was 500mA on USB) because of the same issue and by recommendation from other posts acquired hap ac lite (where it is promised to be 1A).
Hence I would be grateful if someone found the root cause and how to fix it.
gtk
Sat Jul 11, 2020 1:01 pm
Feedback from Mikrotik not very very helpful :)
Multiple messages about diagnosis.
They advise me to upgrade to beta (7) version of OS .
I'll try it but first I have to read about fall-back procedure.
Regards
GTK
mbovenka
Sat Jul 11, 2020 1:59 pm
I have the same stick, and it does the same. With 6.x it flips between two USB IDs, that of a 4G stick and that of a mass storage device, and the link is up when it behaves as a 4G modem.
Upgrading to ROS 7beta8 worked for me connected to a hAP ac.
gtk
Sat Jul 11, 2020 3:22 pm
I'm little bit affraid about using non-stable, beta release.
It's my home router but it is like production environment and it's heavilly used specially these days.
GTK
mbovenka
Sat Jul 11, 2020 4:32 pm
That's a choice you'll have to make for yourself. The 4G stick will work, and my CCR1036-8G-2S+ has been running 7.0b8 for 27 days now without issues. Except that on the CCR1036-8G-2S+ with 7.0b8...tadaa..the USB port doesn't work, so I still can't use the stick where I want it :lol:
MT is aware of the issue, and it should be fixed in the next beta. But that's CCR1036-specific, it all worked fine on my hAP ac.
polmax
Mon Jul 20, 2020 12:00 pm
After the update hAP ac to version 7beta8, the modem Huawei E3272h works fine, but the wifi (CAPsMAN) stops working normally, some clients cannot connect (disconnected, received deauth: class 3 frame received (7)).
If you roll back to version 6.47.1, then everything is ok with wifi, but the modem does not work.
polmax
Tue Jul 21, 2020 8:04 pm
They work quickly :) The problem was fixed in 7.1beta1 (2020-Jul-21 08:58):
!) added FastTrack and NAT hardware offloading support for CRS317-1G-16S+RM;
!) ported features and fixes introduced in v6.47.1;
*) route - added rpki-check;
*) route - bgp improvements;
*) route - do not allow modifying/deleting "main" table;
*) route - fixed incorrectly interpreted prefix states received from RTR;
*) route - fixed IPv6 ECMP connected routes;
*) route - fixed IPv6 policy routing;
*) route - routing rules improvements;
*) wireless - fixed wireless performance for 802.11b/g/n and 802.11a/n interfaces on non-ARM architecture devices;
*) other minor fixes and improvements;
Now both the modem and the network are working as expected, thanks
vvchumanov
Wed Jul 22, 2020 11:49 pm
who make fix on rb2011 , this e3372h-320 ?
on rb2011 (mipse) loss os7.0beta
buyanvla
Thu Jul 23, 2020 11:23 pm
Hi all!
I have exactly the same "blinking lte1 interface" problem with similar configuration (router Microtik hAP ac2 + Huawei 3372h-320 modem, RouterOS v6.47.1)
EugeneV
Wed Jul 29, 2020 9:55 pm
Hi.
Same problem with Huawei E3372h-320 on hAP ac (RB962UiGS-5HacT2HnT and hAP ac2 RBD52G-5HacD2HnD
Any official or owners solution, except upgrade to 7 beta version?
bhickey
Sun Aug 09, 2020 12:42 pm
Same issue here with 6.47.1 on new hex S router.
7.1beta1 fixed it. It would be nice though to have the fix in long-term release.
LindaRef
E3372h 320 USB/lte1 problems constantly LTE1 link up down
Sun Aug 09, 2020 8:17 pm
Multitaps have a specific protocol for reading data that is NOTHING like a pad. If the USB interface only supports pads, you wont be able to use it with a multitap.
Fopwoc
Thu Aug 20, 2020 11:47 pm
same issue!!
Modem: E3272S-153
Mode: HiLink
telegram: @NotCuckold
First year of computer science
katbert
Tue Aug 25, 2020 7:42 pm
Same issue with MikroTik hAP ac and Huawei E8372h-320 (E3372 with Wi-Fi and advanced web interface).
I'm trying RouterOS 6.45.9 and 6.47.2 - no luck
19:44:42 interface,info lte1 link up
19:44:42 interface,info lte1 link down
19:44:44 dhcp,info dhcp-client on lte1 got IP address 192.168.8.100
19:44:45 interface,info lte1 link down
19:44:45 dhcp,info dhcp-client on lte1 lost IP address 192.168.8.100 - lease stopped locally
19:44:46 interface,info lte1 link up
19:44:46 interface,info lte1 link down
neutronlaser
Thu Aug 27, 2020 3:32 am
Only works in new beta.
And probably only when you restart router.
casus
Wed Sep 02, 2020 9:56 am
I confirm the problem with the new Huawei modems that Mikrotik can't digest. It is still difficult to work with the RouterOS beta - some of the functionality does not work or does not work correctly. Developers - please respond, will there be a backport from 7 beta at least in the test 6.48?
pe1chl
Wed Sep 02, 2020 11:35 am
I found this topic when it was linked in the 6.47.2 release topic.
I am using 2 of these E3372 sticks, one on RB750Gr3 and another on RB962UiGS-... and both of them work OK on RouterOS 6.47.1
casus
Wed Sep 02, 2020 12:19 pm
Yes, E3372h-153 works fine.
But last model - E3372h-320 - very not fine... LTE link up/down every 2-3 sec. Supported this model in 7beta2 RouterOS.. Very beta...
pe1chl
Wed Sep 02, 2020 1:37 pm
Ok I don't know the submodel of mine, but it is already over a year old so probably the model that works fine on all versions.
neutronlaser
Thu Sep 03, 2020 3:48 am
Looking forward to a backport.
casus
Thu Sep 03, 2020 8:42 pm
It looks like there will be no backport from version 7 to version 6. Support hints at switching to version 7.
neutronlaser
Fri Sep 04, 2020 10:20 pm
That would be nice but it's betabroken.
boykoaa
Fri Oct 09, 2020 5:42 pm
I had the same problem.
Spent a lot of time and find a solution:
Use another more powerful power adaptor, in my case I fount adapter 12V 5A, power up, and no problem!!!!
My setup Mikrotik RBD52G-5HacD2HnD-TC (7.1Beta2) + E3372h-320
meowmeow
Sun Oct 11, 2020 2:34 pm
I can confirm E3372h-320 the same behavior on my HEX-S Router. Upgrading to latest 7 beta RouterOS will broke setup, in particular
PoE Out not work properly (then my WiFi AP not powered)
PPPoE SFP VDSL link constantly up and down
Downgraded to latest 6.x LT version and all fine again (except E3372h-320 of course)
Possible workaround - find the way to disable mass storage
But as I understand the solution will be only with RouterOS 7 release (is someone know when this may happen?)
ozzyBLR
Thu Nov 05, 2020 8:08 am
hEX RB750Gr3 running 6.47.7 firmware + Huawei E3372 running 10.0.3.1 (H192SP2C983) firmware = flapping LTE interface.
My provider says they can connect to the USB stick and change some services. Not sure what does it mean but let's see what happens next.
SiB
Thu Nov 05, 2020 11:49 am
that modem can have many differ firmwares who works differ way.
support@mikrotik.com or mikrotik.com/support
ant45
Wed Nov 18, 2020 6:44 am
Unfortunately, this version (320) cannot be changed to another firmware, at the moment. All changes are completely prohibited and there is no workaround.
Why isn't a MBIM driver added to version 6 of ROS?!? :(
SiB
Wed Nov 18, 2020 11:08 am
Probably true, until it not be sell to RU then 4pda.ru not do a firmware and not publish that info at bez-kabli.pl where dzeik have his repo: https://www.mediafire.com/folder/ll9ieq ... /Documents
Because KERNEL cannot use it.
pitchfork
Sun Dec 20, 2020 11:51 pm
I also have this issue using a hap Ac2 and E8372h-320. An upgrade to ROS 7 resolves the issue but that release is not stable.
Users browsing this forum: mine25, mveselic and 38 guests
