cpresto
hAP ac³
Tue Sep 29, 2020 10:12 pm
Nice router but something is still missing...
- FXS port (hopefully 2);
- colored WAN port (blu?) and PoE port (red), to avoid Customer's connection mistakes
... a good opportunity missed to made a rotuer to be used at residential Cusotmer's site.
Something like this ... https://www.tp-link.com/it/home-network ... r-vr1200v/
Rgds
neutronlaser
Re: hAP ac³
Tue Sep 29, 2020 10:27 pm
Lol mikrotik barely have Wifi 5 and you want them to start doing FXS
DarkNate
Re: hAP ac³
Tue Sep 29, 2020 11:32 pm
Exactly, like MikroTik markets itself towards WISPs and ISPs, not Wi-Fi.
I honestly don't understand why people buy MikroTik routers for the Wi-Fi. I would just use MikroTik only for routing/switching, that's pretty much it.
cpresto
Re: hAP ac³
Wed Sep 30, 2020 10:55 am
Mikrotik offers unmatched troubleshooting possibility at Customer's site, especially at residential ones.
Many time Customers made mistakes, but the didn't tell you at the phone, e.g. just plug&play a new AP, obviously with DHCP server on (...) and then call the WISP because "Internet connection dosen't work". With other WiFi/FXS router anvailable on the market (TPLink, etc...) the WISP is simply BLIND on LAN side, instead mikrotik offers many troubleshooting possibilities (torch, dhcp client settings on LAN, secondary IP, IP scan, etc ...) on LAN side. Moreover... too many power suppliers means mistakes: only one device (with PoE out for the radio) is perfect, but LAN port MUST HAVE different colors, in order to check with Customers @ the phone if everything is properly connected: e.g. "is the cable that goes to the radio plugged in the RED port?" .
Rgds
normis
Re: hAP ac³
Wed Sep 30, 2020 10:59 am
The port is clearly labeled with the text "INTERNET", which works even for people with poor color perception.
cpresto
Re: hAP ac³
Wed Sep 30, 2020 11:28 am
Believe me Normis "clearly labeled INTERNET" is not enough for tipical residential Customers ;-D
Is some cases they are even not able to find out an electrical plug... ;-D
Rgds
paulct
Re: hAP ac³
Wed Sep 30, 2020 11:42 am
Only thing I wish both the hAP ac2 and ac3 has was a SFP port
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Re: hAP ac³
Wed Sep 30, 2020 2:57 pm
Rgds
Deployed a FTTh solution in a golf estate, first question sked when customers calls in and say they have no internet "is there any red lights on ONU / ONT?", one customer replied yes, and send us a picture of the pre-paid electricity meter :-)
MTCNA, MTCTCE, MTCRE & MTCINE
neutronlaser
Re: hAP ac³
Wed Sep 30, 2020 8:20 pm
lol
DarkNate
Re: hAP ac³
Wed Sep 30, 2020 9:10 pm
Rgds
Next level stupidity.
I've also seen so called "pros" calling an ONT/ONU as a "modem". I'm like "What the heck is a "modem" in Fibre optics?"
For those who will start argument on whether modulation occurs in optics or not, read this: https://networkengineering.stackexchang ... 4461#64461
inteq
Re: hAP ac³
Wed Sep 30, 2020 9:51 pm
Even professionals call them modem because they got used to speaking with non-tech customers that only knows this terminology.
Try talking to your average Joe and tell them about ONU/ONT.
You just tell them modem and they know what you are talking about. No point in correcting them or explaining.
You do not interact with final customers too often me thinks.
SiB
Re: hAP ac³
Thu Oct 01, 2020 1:44 am
Chateau / hAP ac³ - have the same PCB as base system. Dual Possibility for LTE socket M.2/mPCIe
what probably be base for future 5G with external antennas.
In this Chateau LTE12 poor bandwidth user say we can have problems with ISP speed... but he still not provide export...:
haj3s29a
UPDATE - it is poorly described. With queues and firewall filters, max 200Mbps. Everything default + fasttrack 320Mbps
Anyone tried bandwidth test for Chateau, please?
I have got CATV Internet up to 500Mbps but I cannot get over 25MBs (200Mbps) with queues and some filtering. Using fasttrack pushes it to 40MBs (320Mbps) with almost default setting. It looks like that is limit.
Only one core is always 80-100%...average per CPU max. 30%
and this PCB have only 2 antennas for wifi. I think hAP ac² will be a new king of soho after RB951G :)
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I back :) Hello again.
r00t
Re: hAP ac³
Thu Oct 01, 2020 4:12 am
Interesting. There doesn't seems to be missing many SMDs around mini-PciE slot, might be fun experiment to solder it in and see if it actually works. It may as it just needs power and pci-e lanes that should be coming directly from CPU.
SiB
Re: hAP ac³
Thu Oct 01, 2020 10:38 am
They are for antenna connectors but modem itself have own u.FL or IPEX4=MHF4 connectors from what you use directly.
For now I don't know it's limited by software but I am sure someone will try this :D
anav
Re: hAP ac³
Fri Oct 02, 2020 1:00 am
Why go half way, SFP+ that is backwards compatible.
I also want mine to make milkshakes.
Seriously, I must admit I have a VOIP Modem sitting right next to my CCR1009.
No one I know has land line anymore, and a router with a VOIP built-in makes a lot of sense.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
SiB
Re: hAP ac³
Fri Oct 02, 2020 1:22 am
anav
When RJ11 start exist in RB then ppl say, you have rj11, I buy it bcs I think it's support ADSL+ too :)
neutronlaser
Re: hAP ac³
Fri Oct 02, 2020 3:56 am
Add Token Ring support please.
cpresto
Re: hAP ac³
Fri Oct 02, 2020 12:53 pm
anav
FXS is not for ADSL obviously, but to connect existing Customer's phone
inteq
Re: hAP ac³
Thu Oct 15, 2020 3:47 am
Tested today my first hAP ac3
Not impressed. Not even one bit.
Same exact performance as hAP ac2, in a body twice the size, more expensive and with two useless antennae.
Tested a hAP ac2, a wAP ac and the new hAP ac3 in the exact same location with an Intel AX200 client, direct line of sight at ~3-4 meters.
For some reason, the ac3 with its big antennae is + .5 dBm on 5Ghz compared to the other two, in a capsman setup. Same setup for all 3.
hAP ac2 and wAP ac a steady -49-50 dBm.
hAP ac3 a steady -54-55 dBm no matter the antennae orientation. It's like the two antennae are there only for show.
I am really looking for a reason to recommend the newer ac3 over ac2, but cannot find any.
pekr
Re: hAP ac³
Thu Oct 15, 2020 8:00 pm
Wait, I am about to suggest my friend to get hAP ac3, to get more signal over the ac2. So it was not the case? Should have 5db vs the 2.5db of ac2, no?
andriys
Re: hAP ac³
Thu Oct 15, 2020 9:13 pm
Do not mix up the antenna gain and the signal strength. When using a high gain antenna your router has to reduce tx power to stay withing the legal boundaries, so the max signal strength you get is the same. However the effective coverage is usually better, thanks to a better sensitivity on reception.
inteq
Re: hAP ac³
Thu Oct 15, 2020 10:04 pm
Thank you @andriys for point this out. Indeed, you are correct.
I have briefly tested with only one concrete wall between the ac3 and the client and noticed the same behavior.
Tomorrow I will test this more thoroughly and get back with details in an up to 4 thick concrete walls location.
inteq
Re: hAP ac³
Fri Oct 16, 2020 6:20 pm
I know professionals with cool expensive toys will laugh their asses off, but this is the best I can do: one smartphone with WiFiman from Ubiquiti.
wAP ac and Samsung Galaxy S9+
1. Direct line of sight at 3 meters distance
2. Behind a 19 cm thick concrete wall at 6 meters distance
3. Behind two 19 cm thick concrete walls at 15 meters distance
hAP ac3 and Samsung Galaxy S9+
hAP ac2 and Samsung Galaxy S9+
ros44
Re: hAP ac³
Tue Nov 10, 2020 5:48 pm
These tests are absolutely wonderful. One question: did you have the same RouterOS installed on all 3 devices while testing?
Every moment something magical is happening!
inteq
Re: hAP ac³
Tue Nov 10, 2020 6:11 pm
Same exact RouterOS version.
Same exact settings for WiFi, all 3 devices provisioned through capsman 00:00:00:00:00:00 on both radios, with channel 36 (5180Mhz) on 5Ghz, only-AC
All 3 devices tested one at a time, so close to no radio interference.
Only the testing client registered on capsman.
Maybe Mikrotik will release a fix in the future, allowing ac3 with its external antennae to perform better, but 6.47.6(7) is not it.
kos
Re: hAP ac³
Wed Nov 11, 2020 9:11 am
Rgds
https://www.neophotonics.com/whats-diff ... ber-links/
wiesulis
Re: hAP ac³
Wed Nov 11, 2020 10:58 am
Did you specify antenna gain for all the devices when conducted the tests?
inteq
Re: hAP ac³
Wed Nov 11, 2020 4:09 pm
Antenna gain cannot be configured under capsman.
I updated all 3 devices to the latest stable RouterOS.
Reset into capsman mode:
capsman set to auto provision using 00:00:00:00:00:00 MAC on both 2.4 and 5Ghz.
Settings on AP:
-disabled all IP/Services but Winbox.
-disabled all IP/Firewall/Service ports.
-set bridge STP protocol to none.
-set password.
-upgraded routerboard firmware to match RouterOS
No other setting done to ac2,ac3 and wAP, like gain or power.
DeBergz
Re: hAP ac³
Tue Jan 19, 2021 2:15 pm
Hi.
I am also having a wifi coverage problem on ac3.
I purchased a hAP ac3 instead on ac2 because the external antennas but the wifi coverage on 2.4Ghz is average and 5Ghz is bad. My ISP router ZTE H288A has much better coverage.
I tried also fixed channels with the same results.
Did you found any solution to that problem or I purchased a dummy wifi router with big antennas?
- RouterOS 6.48 (Stable)
alibloke
Re: hAP ac³
Wed Jan 20, 2021 10:38 am
Antenna gain needs to be set in the normal wireless settings before capsman is enabled on the cap. It's CLI only now after a config change, but still works AFAIK.
erlinden
Long time Member
Long time Member
Re: hAP ac³
Wed Jan 20, 2021 10:41 am
Can you please share your config?
/interface wireless export hide-sensitive file=anythingyoulike
First the problem, then the solution
DeBergz
Re: hAP ac³
Sat Jan 23, 2021 6:06 pm
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=no_country_set disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid="NikosAfroHome (2G)" \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=no_country_set disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid=\
    "NikosAfroHome (5G)" wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile \
/interface wireless
add disabled=no mac-address=4A:8F:5A:A1:XX:XX master-interface=wlan2 name=\
    wlan3 security-profile=profile ssid="NikosAfroHome (Guests)"
add disabled=no mac-address=4A:8F:5A:A1:XX:XX master-interface=wlan1 name=\
    wlan4 security-profile=profile ssid="NikosAfroHome (Guests)"
Also tried to set country to my country (Greece) with the same results
Users browsing this forum: No registered users and 30 guests
