server8
CCR2004 packet loss
Mon Oct 12, 2020 11:00 pm
I have a seriuos problem with all my CCR2004 when traffic pass from giga interface to 10 giga interface and viceversa I have a packet loss aorund 1% or little less.
According with the block diagram https://i.mt.lv/cdn/product_files/CCR20 ... 200459.png I am thinking the problem is generated in the passive intelligent port extender
CCR2004 is not usable to mix different interface speeds :-(
how is it possible?
mkx
Re: CCR2004 packet loss
Mon Oct 12, 2020 11:24 pm
Do you experience packet loss in both directions equllky or is one direction distinctively worse?
I'd expect problems in packet direction 10G->1G where quite some buffering occurs and enabled flow control should help a lot (another matter is whether flow control actually works).
BR,
Metod
server8
Mon Oct 12, 2020 11:37 pm
We have mainly packet loss pinging from the remote end to ccr2004 gigabit interface, the problem probably occurs when the upstream traffic from the 10G->1G fullfill the ethernet..
Enabling flow control not solve the problem.
paulct
Thu Oct 15, 2020 10:28 am
buffer memory issue? I.e not enough buffer space when going from 10Gbps to 1Gbps and vice versa. Not sure how to get the stats from a Mikrotik on this.
jebz
Thu Oct 15, 2020 11:38 am
There was a similar issue on the CCR1072 where the ethernet port was claimed only to be suitable for management traffic.
viewtopic.php?t=125361
IPANetEngineer
Trainer
Trainer
Thu Oct 15, 2020 4:30 pm
So does the packet loss only occur when the 1G interface is full?
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
server8
Thu Oct 15, 2020 11:49 pm
No when the giga interface receive data from 10 giga interface: the slower port sometimes has to keep in pause the faster one before to receive new packets because the buffer is full or not have the buffer.
IPANetEngineer
Trainer
Trainer
Thu Oct 15, 2020 11:52 pm
What's the lowest throughput (on the 1G) you've seen the packet loss?
server8
Fri Oct 16, 2020 8:46 am
The problem is how fast the data arrive on the giga port from the 10 giga port, you can loose packet also whit 100kb or less. If the number of packets arriving exeeds tha capibility of gigaport to send it you will lose packet.
Generally is around 1% or littble bit less. This is a big hardware poblem for ccr2004 and it is not usable to mix different speed ports.
normis
Fri Oct 16, 2020 10:32 am
The 1G port is for management (winbox, ssh to the router), as it's also labeled on the front panel. This port is somewhat limited, and is meant for what it says. The diagram also gives a clue to this.
server8
Fri Oct 16, 2020 11:58 pm
Normis we are speaking about SFP ports
Maggiore81
Sat Oct 17, 2020 8:09 am
Sincerely I am very disappointed for CCR2004's performance.
We replaced a CCR1036 + 10G switch (with trunks) to a CCR2004 with directly put in DACs cables 10G.
We do about 4.5gb traffic through it.
20 firewall rules, most in RAW for "simple" packet filter at the border.
fasttrack enabled.
4x99% cpu, one 100%.
I tried disabling everything, just fastpath, 80% cpu.
even with 2g traffic the voip was chopping.
Replaced back the 1036, and we are with it now. I could consider the 1072 but I fear the watchdog issues that are on the forum. Till now the 1036 is 2+ years working solid.
we use the long-term ROS.
Dott. Elia Spadoni
Network Administrator
MTCNA, MTCRE, MTCTCE, MTCINE, MTCWE, MTCSE
Spadhausen Internet Provider
Ravenna, ITALY
http://www.spadhausen.com
server8
Sat Oct 17, 2020 11:32 am
A router where you can't mix different sfp ports speeds it's not usable in production, if I deploy fiber I need to have 0% packets loss and no 1% like now.
I opened a ticket [SUP-30387] but for now no solution to the issue :-(
IPANetEngineer
Trainer
Trainer
Sat Oct 17, 2020 4:55 pm
Have you tried changing the interface queues for both ports from hardware-only to ethernet-default ?
You need buffering when mixing interface speeds on any router and i'm not sure what the default buffer capabilities are for the CCR2004.
I would at least try a few different queue types for the interfaces to see if performance improves.
Maggiore81
Sat Oct 17, 2020 6:05 pm
Where can I find precise documentation about queue types?
Well I read the wiki... but I have not found any REAL example of WHERE to use wich queue type or interface type
Dott. Elia Spadoni
Ravenna, ITALY
server8
Sat Oct 17, 2020 9:00 pm
The first think that I have tried before to write here and to open a support ticket.
Paternot
Forum Veteran
Forum Veteran
Sun Oct 18, 2020 12:59 am
But You did a downgrade! Take a look at the performance figures:
https://mikrotik.com/product/CCR1036-12 ... estresults
https://mikrotik.com/product/ccr2004_1g ... estresults
Yes, the 2004 is faster with pure fastpath and big packets, but only in this situation. Everything else, and the 1036 wipes the floor with it. It isn't meant as a direct substitute to the 1036 - it is more something above 1009 and just below 1016.
Yes, each one of its 4 cores is much faster than the 10XX ones - but not enough to offset 4 cores versus 36 cores. It will outperform the CCR10XX series in single threaded activities, but not in firewalling.
Maggiore81
Sun Oct 18, 2020 1:05 am
Hello Paternot, I have read carefully the performance figures, but sincerely I expected a lot more.
I did not expect a 100% cpu load !!!
However I am planning to replace the 1036 witha 1072 because I need the pure 10G ports for each link.
I have some fear to get a 1072 that has issues as in the threads about "watchdog and 1072".
I use conntrack, I use Fasttrack, it is one of my border router.
Dott. Elia Spadoni
Ravenna, ITALY
Paternot
Forum Veteran
Forum Veteran
Sun Oct 18, 2020 6:05 am
Well, I can't speak for the usage model on You network - but if it was taxing one CCR1036, I find remarkable that one CCR2004 can barely cope with the load. I mean, take a look at the results for 512 bytes and 25 ip rules: it's about 1/3 of the 1036 speed!
Maggiore81
Sun Oct 18, 2020 11:39 am
You may be right, I may have chosen the wrong product.
The 1036 was at about 15% average cpu...
Dott. Elia Spadoni
Ravenna, ITALY
server8
Sun Oct 25, 2020 9:38 pm
Any update on this issue?
server8
Tue Oct 27, 2020 11:28 am
server8
Thu Oct 29, 2020 10:34 pm
ozar
Fri Oct 30, 2020 11:45 am
I would just like to say that I experienced the same issues.
I have x4 CCR2004's and when they were in my lab before being shipped to production I had them connected to each other using Mikrotik 1G S-RJ01 Ethernet modules. NSW-RTR-01 (172.16.4.1 - CCR2004) was connected to NSW-RTR-02 (172.16.4.2 - CCR2004) via a Mikrotik 1G S-RJ01 Ethernet module. I ran "ping 172.16.4.2 interface=sfp-sfpplus2 do-not-fragment count=100 size=1500" and received high packet loss. Since I did this a while ago now I would have to dig up this packet loss data if you want proof.
Alternatively Mikrotik you could grab x2 CCR2004's and connect them to each other via Mikrotik 1G S-RJ01 Ethernet modules and run the same ping test and see the packet loss yourself. I don't see any packet loss if the Router to Router connections use 10G interfaces instead. I haven't tested this but I assume 1G Fibre SFPs will be affected too. Hopefully shaping or setting the Tx/Rx Flow Control to on will resolve this issue.
Worth investigating.
ozar
Fri Oct 30, 2020 2:27 pm
I still have x2 CCR2004's that aren't in production yet so I did some testing on them. The CCR2004's are directly connected to each other via sfp-sfpplus2.
I tested with:
- 1G Ethernet module - Mikrotik S-RJ01 - 17% packet loss (First attempt)
- DIFFERNT 1G Ethernet module & Ethernet cable - Mikrotik S-RJ01 - 3% packet loss (Second attempt)
- 1G SM Fibre SFP - Ubqiuiti UF-SM-1G-S - 0% packet loss
- 1G MM Fibre SFP - Ubiquiti UF-MM-1G - 0% packet loss
Obviously something is wrong with the CCR2004 and 1G ethernet modules. In production I have the Router to Router connections as 10Gbps DAC cables and they get 0% packet loss.
Mikrotik S-RJ01:
[x@NSW-RTR-01] > ping 172.16.4.2 count=420 do-not-fragment size=1500 interface=sfp-sfpplus2
419 172.16.4.2 1500 64 0ms
sent=420 received=347 packet-loss=17% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
Mikrotik S-RJ01:
sent=420 received=406 packet-loss=3% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
Ubqiuiti UF-SM-1G-S:
sent=420 received=420 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
Ubiquiti UF-MM-1G:
ozar
Fri Oct 30, 2020 2:49 pm
If I was you I would give shaping just below 1Gbps a shot and see if you still get the packet loss.
I don't use 1G Ethernet modules in productions so I don't have too much skin in the game, goodluck.
server8
Fri Oct 30, 2020 6:20 pm
it not work
server8
Fri Oct 30, 2020 6:22 pm
Can I have an official answer about this problem by mickrotik support? I am pinging every day for ticket [SUP-30387] wihtout any answer :-(
server8
Mon Nov 02, 2020 9:23 am
mkx
Mon Nov 02, 2020 3:27 pm
If you're not getting response through official channels, then you surely won't get any response here. This is user forum (where MT employees might check from time to time and answer some questions) not official support forum.
BR,
Metod
server8
Tue Nov 03, 2020 1:00 am
I have a support tikcet opened without any answer too
oouups
Wed Nov 04, 2020 2:03 pm
Exactly the same problem here !
Tired of playing "Betatester" for Mikrotik. Paid for something that really not Works.. and no one help of them.... THX Mikrotik.
Lost time, lost patience, lost money... and you loose a costumer.
server8
Thu Nov 05, 2020 9:03 am
I am using back old CCR016 to connect gigabit site. CCR2004 is not usable in real because if we have problem to use different port speeds we can't use 25 Gb/s uplink ports with 10 gbis/s ports.
server8
Fri Nov 06, 2020 8:31 am
server8
Mon Nov 09, 2020 8:29 am
mkx
Mon Nov 09, 2020 10:21 am
Not much will happen in 3 days ... specially so not over weekend.
BR,
Metod
server8
Sat Nov 21, 2020 9:39 am
There are a lot of users with same problem around and after 2 months no answer from mikrotik :-(
At this point I have to suppose that is è hw problem without solutions. CCR2004 is an expensive paperweight
Maggiore81
Sat Nov 21, 2020 10:21 am
Hello. I want to tell you my personal experience.
My experience with 2004 was bad because I replaced a 1036, but maybe the 2004 was too "light" for the purpose.
Now I have installed two 2004 with:
1x10g uplink
1x rj01 to AF24 ubiquiti
2x SFP+ 10G to other sites
everything in routing via BGP
0 issues and cpu low.
I tried also to disable conntrack for the routing (previously I used fasttrack everywhere) and 0 issues, just a higher cpu.
Dott. Elia Spadoni
Ravenna, ITALY
server8
Sat Nov 21, 2020 5:33 pm
Please check the tx drop under the tab Tx Stats
Maggiore81
Sat Nov 21, 2020 5:39 pm
Hello
I got 1649 tx drop on the interface with an RJ01 with AIRFIBER24 from UBNT.
it 4 days and 4 hours.
it is a 500mbit link.
no issues from the customers.
maybe the issue you are describing?
The interfaces are routed between each other, so no mixed speeds in the same bridge.
Dott. Elia Spadoni
Ravenna, ITALY
server8
Sat Nov 21, 2020 8:38 pm
Hello
You are loosing packets if you check on SFP28 you 'll find zero tx drops.
Now I have all 10 gigabit pots but I loose packets onyl on sfplus ports.
Maggiore81
Sun Nov 22, 2020 12:32 am
Hello.
I use:
Sfp1 1g sfp
Sfp2 10g link
Sfp3 1g on rj01 with airfiber
Sfp11 and sfp12 on a bridge. Two 1g links
I have drops only on the sfp3 1g.
I don't use 25g ports
Dott. Elia Spadoni
Ravenna, ITALY
server8
Tue Nov 24, 2020 3:25 pm
It depens how fast the trafffic coming on the 10 gibi/s port to be routed or swithed to the other ports.
We are speaking about 0,1% of packet loss that is not to much for a wireless link but is too much for a fiber link.
Maggiore81
Tue Nov 24, 2020 3:33 pm
Everything is routed!
Dott. Elia Spadoni
Ravenna, ITALY
wojrep
Wed Nov 25, 2020 8:56 am
I have a similar problem, CCR2004 post sfp-sfplus2 - SFP 1G insert, no auto, flow controll On ... and I have a lot of drop packages.
They start to appear when I exceed the speed of 100Mbit / s, at 200-500Mbit / s I have several thousand of them per minute, multicast transmission is interrupted (frame stop and IPTV artifacts).
Changing queue improves things a bit, but fails to get stability.
Maggiore81
Wed Nov 25, 2020 10:01 am
Hello
I never found final documentation in how changing queue helps.
I leave them at only-hardware-queue
Dott. Elia Spadoni
Ravenna, ITALY
wojrep
Wed Nov 25, 2020 10:30 am
Today I have tested all combinations with different queue sizes.
There is a difference, if you set ethernet-default and experiment with the size of the queue it may be enough for you.
I checked between 50-1000 packets and there was always a TX DROP problem, with queue values of 150-250 the least problem was. However, I am using multicast for IPTV, so dropping packets too often is unacceptable.
This problem occurs only with optical inserts with 1Gbps link speed, no matter if the insert itself is 1Gbps or 10Gbps.
I went back to CCR1036, wait for the new original MikroTik inserts and check it again.
Maggiore81
Wed Nov 25, 2020 2:27 pm
We use only hardware queue
on the wiki I didnt found any interesting data about changing queue types on interfaces.
Dott. Elia Spadoni
Ravenna, ITALY
Maggiore81
Sat Dec 19, 2020 12:56 pm
I have replaced both 2004 in heavy duty enveroniment (core)
I installed 2x 2004 with FASTPATH and bgp only.
heavy packet loss on 10G interfaces
replaced with a UBNT edgeswitch 16XP and 1036+vlans, work flawlessy
with just 1.5g traffic, cpu at 30% (fastpath) and irq at 15, heavy packet loss.
changed cables, ports. no change.
latest longterm, tried also stable, no differencies.
Dott. Elia Spadoni
Ravenna, ITALY
mhugo
Sat Dec 19, 2020 5:50 pm
We had issues with interfaces dropping using rj01 on 2004s. After replacing with fiber sfps the issues are gone. Could perhaps be power consumption.
/Mikael
andrewe02000
Wed Dec 30, 2020 1:16 am
I have the same problem and opened a ticket with no response over 2 weeks ago. Very annoying. The odd thing is that im only getting the tx drops on the interface going to my elan. At first I thought it was an mti mismatch but have since ruled that out. I even put a CRS309 in between my ELAN and my CCR2004 and the tx drops moved to the interface going to the ELAN on the CRS309 and stoped on my cloud core. I've tried finisar, mikrotik, and fiberstore modules with the same results. Even tried a 1G and 10G DAC from multiple vendors. My ISP for my ELAN checked their equipment and show no drops on their side or FCS errors. It's odd that the problem moved down to the interface on my CRS309 instead of staying on my CCR2004. Even odder is when I unplug the 10G DIA and switch over to my backup 1G DIA the TX drops go away and as soon as I plug my 10G DIA back in they come back. It is weird that the TX drops only show up once you open the interface and not in the column view when I select them. It always shows 0 in the column view on both the crs2004 and crs309 depending on whether or not im using the crs309 inline but shows up after double clicking the interface and going to stats. The other weird thing is that the tx drops don't show up on any other 1G interface on the CCR2004. I would expect it to be consistent at the very least. I set a lab up with all the smae routers and have yet to be able to reproduce the result in the lab and I believe this to be due to the fact that I am not able to tax the CPU load high enough to perturbate the issue. Please Mikrotik. HELP!!!!! My CCR2004 like many others is a paperweight as it is causing out of order packets and voice quality issues even thought the packet loss through the ccr2004 is low at 0.08 to 0.12 percent.
server8
Wed Dec 30, 2020 9:37 am
Give it up I have opened a ticket 3 months a go without any answer. No chance to solve this issue.
markonen
Wed Dec 30, 2020 11:55 am
I even put a CRS309 in between my ELAN and my CCR2004 and the tx drops moved to the interface going to the ELAN on the CRS309 and stoped on my cloud core. … It's odd that the problem moved down to the interface on my CRS309 instead of staying on my CCR2004.
So you think the CCR2004 is causing tx drops on a completely separate device (the 309)? I don't think that's possible.
wojrep
Sat Jan 02, 2021 3:00 pm
There is a problem with Tx-Drop on mikrotik 10Gbps interfaces in combination with any 1Gbps interface.
Even at speeds of 100Mbps, TX-drops arrive quickly.
andrewe02000
Fri Jan 08, 2021 9:00 am
I opened a support ticket on 12/21/2020 and still no response! This is obviously an issue and we deserve answers. Anyone else had luck with a support ticket?
wojrep
Fri Jan 08, 2021 11:13 am
I also have an open ticket, but I'm waiting longer ... no reaction.
mhaluska
Sat Jan 09, 2021 12:41 am
I've also problem with tx drops on switch (CRS317). Never had this problem before with RB4011. Tx drop are only on interfaces connected to CCR2004. Tested "overloading" ports connected to server with CHR -> not drop, no issue.
wojrep
Sat Jan 09, 2021 2:29 pm
In the case of connecting the 10G interface to the 1G interface and additionally overloading the 1G link with the test, the appearance of Tx-Drop is a rather natural situation.
It is not natural for them to appear even further up to 1G, e.g. at 200Mbps.
andrewe02000
Mon Jan 11, 2021 8:28 pm
At this point both units are bricks to me and I am going to return the units I purchased as they are paper weights and no response from the vendor. I get that we have COVID going on right now but a brand new product with multiple people having the same issue deserves an answer I would think. My network can't take much more of this before I have to break down and spend big bucks for Juniper.
andrewe02000
Mon Jan 11, 2021 8:44 pm
My carrier has been helpful on scheduling a 10G port upgrade on my 1G ELAN going to the CCR2004 to see if this helps on the 22nd. If this does not fix the issues I am shipping these back. Resume pulling hair out.
andrewe02000
Mon Jan 11, 2021 8:47 pm
Oh also of note trying to generate support.rif crashes the router horribly and requires physically removing power from the unit. Lovely.
server8
Tue Jan 12, 2021 8:52 am
We have in production several CCR2004 and all have problems about packet loss on 10 Giga sfp+ ports no problem of packet loss on sfp28 ports used at 10 Giga.
It's an hardware problem without solutions.... :-(
mblfone
Tue Jan 12, 2021 10:03 pm
I appreciate this post but do not appreciate the lack of response from MT on this. I need these CCR2004 routers but am NOT ordering them from MT due to this issue being unresolved.
Again, thanks for the posts!
server8
Wed Jan 13, 2021 12:14 pm
Give it up it's normal from mikrotik the lack of response when they can't resolve the problem.
andrewe02000
Thu Jan 21, 2021 6:02 pm
I am just going to post here every day this goes unanswered in the forum and my support ticket.SUP-37056 opened on Dec 21, 2020 11:30 EST goes unanswered. STILL NO ANSWER 1 MONTH LATER.
andrewe02000
Fri Jan 22, 2021 10:30 pm
I understand this. But the fact was we weren't maxing out our 1036 it was overpowered but we still didn't have a 10-gig interface. Even after disabling all of the firewall rules on this unit we still have problems with it being able to do line rate with what it says it can do without errors. Just last night I upgraded all of my circuits to 10 gig ports which took an arm and a leg to get my service provider to upgrade a one gig service to a 10 gig port but I digress. After all of that last night I still have TX drops on the interfaces and about 0.1% packet loss. I even tried turning off mpls and any other feature like ospf and did static routing and still had the same problem. it's not that the box is overloaded it's that the hardware has problems and the vendor is not acknowledging it.yes I am looking at the solution that you implemented as a possible solution compared to just buying an mx80 DC unit at 3K and being done with my life. if a vendor sells a product and says that it can do line rate 10 gig it should be able to do it. Anything besides that is either a lie or gross negligence. Not answering support tickets for customers or telling them that they're working on the problem or acknowledging them in anyway for over a month now. Day 31 for me. That's a problem. Network service providers expect communication from their communication vendors. Even if it's just a little bit instead of being left completely in the dark. There is my post for the day.
Sent from my Pixel 4a using Tapatalk
andrewe02000
Sat Jan 23, 2021 11:11 pm
@normis 1 month 2 days. Can we get a response to this in the forums or on our support tickets?
server8
Sun Jan 24, 2021 1:37 pm
I have a ticket, on this issue, opened 5 months ago and I am still vaiting for an answer
andrewe02000
Sun Jan 24, 2021 9:18 pm
Another post for the day. 1 month and 3 days.
andrewe02000
Mon Jan 25, 2021 5:17 pm
And another day. 1 month 4 days.
Paternot
Forum Veteran
Forum Veteran
Mon Jan 25, 2021 8:24 pm
Stop this nonsense. You are just polluting the topic, and this helps no one - far from it.
andrewe02000
Fri Jan 29, 2021 5:48 pm
I'll stop when I get a response.
1 Month 8 days no response.
andrewe02000
Fri Jan 29, 2021 6:10 pm
If no one says anything then nothing will get done. We don't deserve to be left in the dark. Regardless of what's going on. The squeaky wheel gets the grease. I'm not going to stop squeaking until I get some grease.
mhugo
Sat Jan 30, 2021 12:10 am
You might be squeaking on your own - I unsubscribed because of the noise.
6.48.1 is out soon - lets hope for some more 2004 improvements in that.
/Mikael
Paternot
Forum Veteran
Forum Veteran
Sat Jan 30, 2021 2:15 am
Do a constructive squeaking, don't be this person. Post tests, ideas, suggestions. One post a day, just saying "I'm a victim, Mikrotik doesn't love me" don't help anyone - and will not solve the problem faster either.
Robervaldd
Mon Feb 01, 2021 11:42 pm
I have two ccr2004 here with the same packet loss problem, almost certainly the problem is in the hardware with no solution!
mikeeg02
Wed Feb 03, 2021 3:04 pm
Could be interesting
6.49 released.
switch - improved packet transmit between CPU and 98PX1012 for CCR2004-1G-12S+2XS device;
viewtopic.php?f=21&t=172259&sid=b361e20 ... ddcaa12707
It's a beta, so test it out first.
mhugo
Mon Feb 08, 2021 5:21 pm
6.49 released.
Anybody dared trying it?
/Mikael
andrewe02000
Mon Feb 08, 2021 7:46 pm
I ended up pulling my units and not a fan of running beta in production. Maybe I'll get a lab going and try to reproduce this.
mhugo
Mon Feb 15, 2021 7:07 pm
6.49 released.
6.49beta11 did not fix packetloss but interface instability. BUT beware - all ports negotiate in full 10G even if SFP is 1G. Works kind of until it becomes unstable causing ospf to flap.
Also got this which Im testing on one box right now. Kind of defeats the purpose on 10G interfaces but very fast initial testing seems promising and mostly we are below 1 gig so its peferable to packetloss.
Regarding packetloss apply these settings on SFP+ ports which report tx-drop
/queue type
add kind=pcq name=queue1 pcq-burst-rate=990M pcq-burst-time=20s \
pcq-limit=2000KiB pcq-rate=980M
/queue interface
set sfp-sfpplus1 queue=queue1
/Mikael
andrewe02000
Wed Feb 17, 2021 8:18 pm
6.49 released.
/queue type
/queue interface
/Mikael
I got this same message from tech support to try this exact same thing. It actually made the packet loss worse from 1 to 2 packets out of 1000 to 8 to 10 packets out of 10000 on any interface I put the rule on so yeah. Also did not fix tx drop errors.
maznu
Thu Feb 18, 2021 11:53 am
Same here (though what we were sent didn't look like a full command). We're having packet loss when using only two 10G interfaces, but only when routing production-like traffic (i.e. lots of src and dst addresses). A single iperf runs fine.
Support ticket to MikroTik updated with full details. We've been working with them for a month now — hopefully the test cases we've got are helping.
Marek
maznu
Thu Feb 18, 2021 4:49 pm
…and now same here with the 6.49beta11 "SFP at 1G is not stable" bug.
Marek
mhugo
Thu Feb 18, 2021 4:51 pm
For us the 1Gs report 10G. Same for you?
I think Mikrotik should make a seperate 2004 release based on long-term and fix this without mixing it with all other fixes.
/M
maznu
Thu Feb 18, 2021 5:06 pm
Hard down, will not establish link. Light is received, but port does not negotiate or come up when set to 1G.
Marek
Users browsing this forum: odie and 26 guests
