Hoov
PowerBox question
Mon Nov 09, 2020 2:03 pm
I am trying to configure a Powerbox RB750Pr2 using the POE in port to power it, and also to carry internet into a house. I was also trying to use a Ubiquiti M2-400 as a station, and a Mikrotik SXTG-2HnD as an AP. If I connect the M2 it works fine, but as soon as I connect the SXT, I loose the connection to the M2.
Does anyone have an idea what would cause this?
And to make it even crazier, if I use a Mikrotik Radio instead of an M2, then it works fine after connecting more radios to the powerbox. This is what I am doing, but I would like to know why using an M2 causes problems.
Hoov
Re: PowerBox question
Thu Nov 12, 2020 8:41 am
Well it turned out to be even stranger than I knew. Here is the setup.
100 ft of Cat6 from the power supply to the Powerbox. Connected to the powerbox is an LHG 2 XL and an SXTG-2HnD. Attached to the POE injector 100 ft away from the powerbox is a google nest router. As far as I can tell, this setup should work. And plugging in everything except the SXT everything works as advertised. And it works well. But as soon as I plug in the SXT, the LHG and SXT shart cycling. I get into the powerbox, and it shows that both radios are shorted. If I turn the POE setting for the SXT off, the LHG works fine, and the other way around as well. Now here is where it gets strange. I have a 22400 mah battery I use to power a MaP for aiming CPE's and other things. I connected this battery, just the battery, to the powerbox and everything works great.
Is there some sort of restrictions on the POE in that I am missing?
Łukasz
Thu Nov 12, 2020 1:09 pm
Try on RB750Pr2 set:
/interface ethernet poe settings set ether1-poe-in-long-cable=yes
Hoov
Thu Nov 12, 2020 7:28 pm
Thank you Łukasz! That did the trick! Do you know if there is a list of the command line only options?
krafg
Long time Member
Long time Member
Thu Nov 12, 2020 7:35 pm
Today I ordered a Bullet AC. I have a PowerBox with 2 Basebox and 1 LtAP connected. I will try it.
Regards.
If you want to know my network, you can find it here.
Łukasz
Fri Nov 13, 2020 1:00 pm
Your welcome. Try use "?" in console line. You can use "?" in each branch of command. For example: "/interface ethernet" and then "?".
krafg
Long time Member
Long time Member
Wed Nov 18, 2020 2:25 am
Today I connected my Bullet AC to my PowerBox, and all works perfect.
Regards.
Hoov
Mon Nov 23, 2020 9:05 am
My problem may have been related to the long line POE in. Because sitting in my living room and using 10ft cables it all worked. I am going to be doing a few more of these remote Power supplies, I am sure I will find out with one of them. If I do I will post it.
krafg
Long time Member
Long time Member
Mon Nov 23, 2020 6:12 pm
Anyway use good quality cables with PoE is very very important.
100% cooper and recognized brand like Leviton/Brand-Rex, Panduit, AMP, etc.
In my case I use Leviton Cat. 6A shielded cable.
Regards.
Hoov
Mon Dec 28, 2020 8:50 pm
I used True Cable Cat6 shielded buriable outdoor cable. Once I made the change that Łukasz recommended, all was well in the world (or at least at that one customers house).
Users browsing this forum: Bing [Bot] and 56 guests
