captainproton
CCR2004 packet loss over 10G Interfaces
Tue Nov 10, 2020 9:44 am
Hallo,
I have a new CCR2004 here and been testing in different constellations.
We only used 10G connection. We connected a Juniper Router, a DWDM System, a Server and a CCR1016.
In any setup we saw significat PL in all directions. The only counter that was running and looked suspicious was the TX Drop on the according outgoing interface. But why are those packets dropped?
We were using hardware-queues only, but the ports did not nearly ran at full capacity and the PL continiously occured anyway. eg. at 100 MBit load
What I consider very sange is that this is the deault setting for a SFP+ Port. This leads to the port links at 10G even though the rate is not selected and behaves ever weirder.
default setting:
also funny, paket statistics for packets > 1023 missing
Something is very wrong with this router. Don't buy before you hear that this is fixed.
server8
Re: CCR2004 packet loss over 10G Interfaces
Tue Nov 10, 2020 3:04 pm
Same here viewtopic.php?f=3&t=167512 opened ticket 4 weeks ago witout any solution from mikrotik.
captainproton
Tue Nov 10, 2020 10:14 pm
I have seen your post but I thought it was more specific about traffic from 10G to 1G interfaces.
torstorm
Tue Nov 10, 2020 10:34 pm
Hallo,
default setting:
I also have this router and all is looking normal, dont have any drop packets . I also use 10Gbit sfp+ modules from Finisar.
server8
Wed Nov 11, 2020 8:28 am
Ros version?
markonen
Wed Nov 11, 2020 1:25 pm
I took counter samples from three of the seven CCR2004s I have in production and the TX drop rates for the busiest interfaces were:
* 1/23536 packets dropped (0.0042%)
* 1/76566 packets dropped (0.0013%)
* 1/104768 packets dropped (0.00095%)
These are all on 10G ports with 10G fiber links and ROS 6.47.2 or 6.47.3.
torstorm
Wed Nov 11, 2020 8:06 pm
Ros version?
ROS version is 6.47.7, but I think this router is meant for ROS 7 when it will be stable. ARM64 is better in 5.6.x kernel... :)
server8
Wed Nov 11, 2020 10:38 pm
I am checking deep and I have discovered that packet loss is only on the SFP+ port s, using 10 giga module on the SFP28 ports we have no packet loss.
According with the block diagran https://i.mt.lv/cdn/product_files/CCR20 ... 200459.png the SFP+ and SFP28 ports have different bus to the PIPE
mkx
Wed Nov 11, 2020 11:31 pm
I think it was mentioned that ROS v7 will be running kernel 4.19. But I guess this can change before stable v7 gets rolled out, new linux kernel LTS was announced after the rumour circulated (5.4).
BR,
Metod
torstorm
Thu Nov 12, 2020 6:35 am
I unpack ros7.1 b2 , but looks like there is kernel 5.6.3, maybe i am wrong?
captainproton
Thu Nov 12, 2020 9:36 am
We were using ROS 6.46.8 for our testing.
Upgrading to 6.47.8 would be worth a trial, but somehow I am sceptical...
morf
Thu Nov 12, 2020 10:45 am
I'm sorry if I'm off topic. I can't find any real test results in CCR2004 anywhere. Please tell me how much traffic you have going through the most loaded CCR2004 and what is the load on the CPU ?
markonen
Thu Nov 12, 2020 2:38 pm
Our CCR2004s currently do BGP (full table) and have a simple Raw firewall (conntrack disabled). So with BGP running and no fasttrack/fastpath, we can saturate the main 10G egress interface with web traffic (a few thousand simultaneous flows). One of the CPUs is pegged (the one doing BGP, this is ROS6) and the rest are well-utilized on traffic peaks, but not at 100%. Sorry, don't have more exact figures at the moment.
Overall we can just about serve our workload with these, and that's pretty amazing considering the price point. But really looking forward to testing a CCR2016 and the rest.
torstorm
Thu Nov 12, 2020 7:36 pm
Thats strange.... I use Finisar FTLX8571D3BCL sfp+ modules, test 10Gbit bandwith and no errors. I also use complex firewall with multiple chains and processor is not loaded even 1/3 of 100%.
On SFP+ modules I use auto negotiation.
For switch i use Mikrotik CRS358 series switch. Maybe you have problems not on router, then on switch side. What switch do you have?
Users browsing this forum: No registered users and 47 guests
