Mett
RB4011: SFP power cycle?
Tue Nov 17, 2020 3:59 pm
Hey,
I'm using a CarlitoxxPro SFP-ONT with a RB4011. When the RB4011 reboots, the SFP ONT is not available. What I have to do is removing the module and plug it back in.
Obviously I need to power cycle the SFP. Is there a hidden option which makes that happen?
forum.mikrotik@honig.do0.de
Elans
Re: RB4011: SFP power cycle?
Thu Nov 19, 2020 8:46 am
Hello Mett,
No, unfortunately, there is no such option.
msatter
Thu Nov 19, 2020 11:00 am
You could try this as scipt running (Terminal) after the router has booted and see if that helps:
disable sfp-sfpplus1
:delay 50ms
enable  sfp-sfpplus1
My scipt-code in PPP Profile for not obtaining a MTU of 1500:
:delay 4s
/interface
:if (([pppoe-client monitor pppoe-out as-value once]->"mtu") < 1500) do={
:delay 50ms
enable  sfp-sfpplus1
:log warning "PPPoE MTU lower than 1500 so the SFP port is restarted"}
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta58 / Winbox 3.27 64bits / MikroTik APP 1.3.15
Mett
Thu Nov 19, 2020 11:12 am
No, unfortunately disabling the SFP port and reenabling it doesn't helps in this case. At the moment, I have to remove the module after boot and plug it back to the cage so it works.
Users browsing this forum: No registered users and 37 guests
