mrtur
R11e-LoRa8 pcie card not detected
Wed Nov 18, 2020 10:27 am
I'm using some Ltap-LTE kits with extra R11e-LoRa8 card and routerOs/lora package 6.47.7 and after reading viewtopic.php?t=160605 I've found how to enable the card by doing:
 /system routerboard usb set type=mini-PCIe
It worked, but after a while the cards disappear from the LoRa interfaces list, and I have to do this command again in order to make it work again!
It happened on several of our Ltap-LTE, so I'm very concerned because I've just started to launch some gateway in production...
Is this a know bug? Is there a fix?
SiB
Re: R11e-LoRa8 pcie card not detected
Wed Nov 18, 2020 8:56 pm
It;s like bug. This not should be like any magic, it's should work or not.
Aks support@mikrotik.com or https://mikrotik.com/support
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
At vacation until 15.jan.2021
Users browsing this forum: Bing [Bot], garlicbulb and 48 guests
