carl0s
10 second reset does not put CapAC into CAP mode!!
Fri Dec 11, 2020 1:32 am
So frustrating
the 10 second reset doesn't put it into cap mode.
choosing CAP from the QuickSet doesn't either, although it does leave the wifi not active and still eth1 firewalled so you have to go and physically reset.
6.47.8
LSan83
Re: 10 second reset does not put CapAC into CAP mode!!
Fri Dec 11, 2020 5:22 am
Don't count exactly the seconds. Checks the led's blinking scheme instead. On my Wap AC is less than 10 sec.
erlinden
Long time Member
Long time Member
Fri Dec 11, 2020 10:43 am
Alternatively you can Reset Configuration and choose CAPS Mode from there.
First the problem, then the solution
bpwl
Fri Dec 11, 2020 6:10 pm
.... or add ether1 to the bridge. You will get in from there.
carl0s
Sat Dec 12, 2020 10:35 pm
It seems like I did need to count to 11 instead. I was getting very frustrated. It was midnight and I already said I was leaving to come home 1 hour earlier.
But..
Both the '11 second' reset (yes, I know, it's just my bad timing of seconds), and the QuickSet 'caps' mode did not work. It looks like they did not set the discover interface on the capAc. I chose 'bridge all Lan ports', 'address automatic/any" and then I was met with nothing.
So the QuickSet didn't work at all and neither did the 11 second mode change to caps client.
I was using eth1 for poe-in and network in.
I had to set up from default configuration manually in the end after a lot of frustration and I missed a lot of sleep from getting home so late 🥱
gotsprings
Mon Dec 14, 2020 1:03 am
I just connect to the device via default wifi.
Open winbox.
Select system
Reset-configuration
Skip backup
Caps-mode
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
carl0s
Wed Dec 16, 2020 12:27 pm
Open winbox.
Select system
Reset-configuration
Skip backup
Caps-mode
I will try that way when I return to fit the second AP in the next week.
Usually the first thing I would do is upgrade the firmware. Maybe that's where I'm going wrong.
I don't know whether to test your method, but with firmware update in-advance, and see if it somehow is breaking the caps-mode default configuration (missing/bad configuration of capsman discovery interface), or just do as you've said.
gotsprings
Sat Dec 19, 2020 2:36 am
Once in caps-mode
I use telnet to:
Update packages
Reboot
Update routerboard
Reboot
Mark Twain
Users browsing this forum: No registered users and 29 guests
